Problem solved
Posted: Tue Sep 07, 2021 9:03 pm
by Polobear6r
Issue is resolved
Re: Still lambda issue after new catalytic converter
Posted: Tue Sep 07, 2021 10:02 pm
by iichel
Mogelijke oorzaken:
Kortsluiting in de referentiespanning van de lambda-sensor
Lambda-sensor vervuild of defect
https://www.gerritspeek.nl/vag-com_dtc-16518.html
It's not really unsafe to drive with, but you'll probably miss a few horses and use some more fuel in the process.
Posted: Tue May 17, 2022 10:46 pm
by Polobear6r
Issue is resolved
Posted: Wed May 18, 2022 7:15 am
by amer6R
Seems that the heater coil inside of lambda sensor is kaput.
What brand of lambda sensors dis you put on your car?
Posted: Wed May 18, 2022 7:23 am
by Polobear6r
Issue is resolved
Posted: Wed May 18, 2022 7:36 am
by iichel
Bank 1 sensor 1 is the sensor upstream of the catalytic converter. Bank 1 sensor 2 is the one downstream of the catalytic converter.
Posted: Wed May 18, 2022 7:58 am
by amer6R
Maybe try with NGK or Bosch ?
Posted: Wed May 18, 2022 2:02 pm
by CarbonChaos
At that price 6 months is good going ,only use OEM or OEM makers sensors,others work ok for a limited time only
Posted: Fri May 20, 2022 3:04 pm
by RUM4MO
amer6R wrote: Wed May 18, 2022 7:58 am
NTK is the brand name for NGK sensors and tends to be what VW Group fit at engine plants and sell as spares.
Maybe things have changed over the past 10>15 years, but when I checked back then, I found that buying locally from a VW dealership was very close in price to buying an NTK same part online and getting it delivered.
Posted: Sat May 21, 2022 1:50 pm
by amer6R
Thats a really useful information.
With sensors, buy cheap pay it twice.
