GTI (AW) REVO stage 1 Beta test review
Posted: Thu Sep 30, 2021 12:53 pm
Thought I’d write this post as a lot of the members here have mentioned wanting a stage 1 but have been patiently waiting for a reputable company such as REVO/Racingline to release it.
I recently was contacted by a garage to take part in the BETA test for the REVO stage 1 for the GTi, I had the map installed earlier this week and just updating the differences to see if those members would feel it would be worth it!
First off, the product is still unavailable, it is due to be release during November after some final tweaking using the testers logs so that’s good news!
In terms of differences:
The stage one software provides a 65hp & 105nm gain. Putting the vehicle at around 262hp and 425nm.
The power difference is honestly unreal and nothing that I expected. I am still running factory bridge stones on the front with around 5mm tread and the power delivery is very smooth and I rarely break traction (unless wet).
The jerky drive from the vehicle when stock felt very jittery and the car didn’t know what gear to be in. The remap has reduced this but not completely - the car now feels a lot smoother when driver at slower speeds in sports mode but can sometime change up at 4000rpm in second if you floor it just before the car was about to change up. - the release has said a gearbox remap will fix these issues but I haven’t had this done yet.
A few users here mentioned that they want a little more kick at the top end as the car dies after 4500rpm, this certainly fixes the issue but it adds a hell of a lot more kick in the lower gears and across the entire rev range which may make your general driving not as comfortable.
In terms of realistic MPG, prior to the remap I was achieving the following; long journeys of 80 mile + = 48-53mpg cruising. Medium journeys of 20/30 miles = 40-42mpg and short journeys = 28-33mpg.
After the remap these numbers looks similar but the mpg isn’t as good.
Long journeys = 44-46mpg.
Medium = 38-40mpg
Short = 30mpg & less 99% of the time.
As for the map I would say it’s 100% worth it, I just wanted to share my experience with the map as I’ve had the opportunity to get it early.
I will update this thread after the 2 week mark and then after a month to see if it’s caused any problem etc.
Hope this is useful to someone!
Medium = 38-40mpg
