UK-POLOS.NET - THE VW Polo Forum • Heater Control Unit - No Illumination
Posted: Tue Jan 25, 2022 6:28 pm
by georgebarlowr
Hiya all,
I have a Polo 6R Match 2014 build, and the heating control unit lights are all out (the AC still works as normal with hot and cold air). However this issue is apparent when I try to click the AC button or Recirc button (I get no illumination on the switch), and also when I turn on all the interior night lighting (the lighting trim around the heater control knobs do not illuminate).
All of the other interior lighting works, and trim illumination.
Do you guys think this could be a fuse issue, bulb issue, or something more serious that I should get checked out by a garage?
Thanks,
George
Re: Heater Control Unit - No Illumination
Posted: Tue Jan 25, 2022 8:51 pm
by iichel
Check the fuse
Posted: Tue Jan 25, 2022 9:05 pm
by georgebarlowr
iichel wrote: Tue Jan 25, 2022 8:51 pm Check the fuse
Do you have an idea of what fuse might be linked to this sort of thing? I'm not too sure what fuse covers the lighting for the heating control unit.
Posted: Tue Jan 25, 2022 9:48 pm
by iichel
Have a look at the fuse overview and check the fuse for the airconditioning unit.
Posted: Sat Sep 07, 2024 9:39 pm
by jfish06
Hi did you ever fugure this out i have the same problem and cannot find the fuse if that is the problem
Please help
