256mm rear brake upgrade for a 6C GTI
VwSeatCupra
Drives: 16' ibiza cupra (same as 6C polo gti)
Post by VwSeatCupra »
Hello guys!
First post here as im struggling to find information on the topic. Ive picked up some 256mm rear brakes but the carriers are off a 4WD car. I know these do not fit now, but at the time i didn't understand the reasons why.
So is it simple enough to purchase 2wd carriers and swap them over?
Or have i wasted my money :shock: :oops:
Thanks!
Re: 256mm rear brake upgrade for a 6C GTI
I think so, some time ago I made the same mistake and ended up buying new 2WD calipers from Polo WRC. Used they are impossible to find.
If you're interested, I'll be selling my rear 256mm kit since I'm switching to something else.
VwSeatCupra
Yeah i struggle to find them also. But as far as im aware 2WD carriers off a Leon cupra r MK1 TT etc should fit. Just want to check before i spend again
As for the sale, not right now mate but if it turns out i cannot fir them then i may have them off you
Yes the 2WD carriers from cupra 1M, TT 8N, Octavia VRS and Golf 4 Jubilee edition will also work.
what about the spacer? with 4wd
Yes, Epytec has adapters for that, but that won't work, it doesn't offer the required stiffness.
Are you sure, they have TÜV
Yes, I had a set myself and it seems to be a common issue on the German forums.
Do you still have them? If yes can you place them next to the ruler and take a picture from top, and measure the thickness. I'd like to redraw them in CAD to do stress testing.
Or just overall length, hole size, thickness and center to center dimension
