Can someone shed light on my situation
Hello everyone I’m new here I have a 2013 6r rline 1.2 tsi I’m having some problems with it I plugged it in and I got a code for cylinder 3 misfire. Well I have changed the spark plugs and the coil pack(I’m no mechanic all done via videos) I’m now having another problem. If I drive the car nice and easy it’s okay but when I floor it it throws loads of white smoke out the back eml light traction and epc lights come on I turn the car off and on they go away it drives normal again I’m stumped and I do have it booked in to a local garage soon
- Drives: MY12 Match (plus tinkering...)
Re: Can someone shed light on my situation
Are you sure the spark plugs went in cleanly and tight? Hard to tell from the description but could it be compression loss at higher output? Maybe take plugs out and check for soot marks outside threads.
