ciclo wrote: βSun Sep 18, 2022 6:10 am
What is absolutely OEM is to use the fuse holder for two fuses 6R0937530, being able to use 2 fuse holders in the same receiving hole.
Crystal clear explanation .. thank you Master.
ETKA also mentions of only 6R0937530 and not 6R0937530A for my T-roc fuse carrier. I will buy couple of both to have more flexibility during installation
I feel you have memorised ETKA fully.
Re: Patil's T-roc 2020 1.5Tsi evo+Dsg7 RHD
Posted: Thu Sep 22, 2022 4:23 pm
by patil
Log: 1
My first mod after buying T-roc--- HBA/FLA Success!!!
My t-roc has all the necessary hardware for HBA/FLA from factory, I only had to activate few adaptation channels in BCM and code the A5 camera to activate HBA. I guess the HBA functionality was disabled from factory in Indian version of T-roc.
Coding: For led projector headlights + A5(3Q0) camera from factory.
HBA gets auto activated when vehicle speed reaches 60km/hr or above and deactivates at 30km/hr when pre set conditions are fulfilled( Owner's manual).
I couldn't find the adaptations to lower the activation speed in either BCM or A5 camera. With 7E0 HBA camera installed in my 6R, there is an adaptation channel to set the desired speed and also many other adaptations to play with.
Why my wife( my 6R new owner ) should only have all the fun.
Posted: Mon Dec 05, 2022 7:35 pm
by patil
My T-roc AID (MY 2020): A flawed beauty!
I liked everything about my T-roc AID except one thing, ie missing clock on top centre of display.
It's a minor but significant flaw considering you need to take your eyes off the road to look at MIB to see the time! Heck.. even my old 7 year old polo has time displayed on IC.
VW corrected this blunder from MY 2021 T-roc.
I was determined to see if this injustice can be fixed in my T-roc AID. I started investigating this issue, and the more deeper I went into the rabbit hole, more startling information I found which I would like to share here with everyone.
To begin with I obviously started looking at long codings and adaptations of addresses 17, 19 and 5F. Hit a dead end there.. there is no such coding or adaptations to enable time on AID. Further in my naivety I messaged few cluster experts in Drive2 forum but there was a silence, no one replied. Then I contacted a senior technician at my VW dealer to see if he knows something. He replied positively and told me to get my T-roc, there is a firmware update for AID which might fix the problem.
My T-roc AID firmware was updated by loading the firmware in SD card in 5F control unit in glovebox. The entire process took around 20 minutes.
Flashing process:
The AID goes blank during flashing.
Comparison of SW version before and after update.
After successful update, the cherished time did not appear on AID.
Later on I found out that, there was an TPI issued by VW in the form of firmware update to fix the automatic trip reset issue on few batches of AID of PR series 9S0. I never faced the issue of trip values resetting automatically to 0 in my T-roc AID! The firmware update didn't bring anything extra functionality wise. Back to square one again.
With hopes dimming, I went to an extent of considering to install new AID from 2021 Model T-roc That's when interesting revelations came to surface.
Here is the brief summary of why I cannot buy a brand new AID from 2021 T-roc onwards and install in my 2020 T-roc even though both look same. Devil is in the details and there is more than meets the eyes.
1. The newer AID's installed from MY 2021 onwards has different part no (17A 920 320B HW502/523, SW5175/6170 etc..), compared to mine 2020 AID (17A 920 790B HW 502/ SW4193). Both AID's are not intercompatible because immobilisers are different. Not only immobilisers are different, VW has changed the way AID's handshake with 5F(MIB unit) from MY 2021. My 2020 T-toc AID communicates with 5F through fibre optic cable (MOST) and AID's from MY 2021 communicate with 5F through Ethernet cables! The reason for such a change is due to introduction of MIB3! from MY 2021 across the MQB car models.
Thanks to my VW service centre senior technician for permitting me to click few pictures of MIB3 installed in MY 2021 T-roc, which was at dealer for accident repairs.
MIB3: Interestingly, MIB3 control unit is totally sealed one without CD drive and without SD card slots. I guess MIB3's can be accessed only through UBC-C ports installed in central console of T-roc MY 2021 onwards.
MIB3 quadlock connector with Ethernet wires:
They say time is money, I have neither...
There are many updates which have happened in my T-roc, details coming soon.
Posted: Sun Dec 11, 2022 9:41 am
by patil
Log#2
Extra fuse holder:
Prepared an extra fuse holder in my T-roc for upcoming retrofits.
The SC fusebox in my T-roc is located behind the Glovebox on passenger side. In order to access behind the fusebox, I had to remove the entire glovebox, 5F control unit, BCM connectors, BCM and then slide fusebox towards us by releasing the locking tabs. I read the repair manual atleast 5 times before venturing in. Without removing the BCM out from the fuse carrier it was impossible to route the wires of new fuse holder. It's all severly cramped place out there.. it was a nightmare!!
With lots of patience and perseverance, without breaking anything, fuseholders were installed into fuse carrier successfully.
This particular image may be has a reason to smile
Now my T-roc is ready for retrofits OEM way.
Posted: Sun Dec 11, 2022 10:13 am
by iichel
Nice, well done, very neat!
Posted: Sun Jan 01, 2023 10:14 am
by patil
Log#3
Backlit front reading light:
Negotiating front reading light buttons is a pain at night due to the absence of illuminated buttons in T-roc. Strangely near by Sunroof switch is backlit! I didn't understand the logic of VW engineers here.
So decided to fix this inconvenience. Luckily VW provides illuminated buttons of reading light in other models such as Golf7, Arteon, Passat etc.. which can be interchanged between T-roc reading light. I bought one such reading light with sunroof switch of Golf7 from eBay.
I bought LHD reading light rather than RHD, as the buttons layout suits my requirements.
Comparison picture: Top T-roc, bottom Golf7
Backside:
Part numbers:
Wiring diagrams:
Due to the presence of sunroof with illuminated switch in my T-roc, it was easy for me to tap KL58d signal from adjacent sunroof switch connector.
Connection for new backlit reading light:
Some installation pictures and result:
The outcome:
Other observations:
1. The replacement is 1:1, no modification is required whatsoever.
2. The pin assignment(T6)of these reading lights is same across all the car models irrespective of RHD or LHD or functionality.
3. The Leds of Golf7 reading lights are brighter than my stock reading light.
Small small things can make a difference and improve our driving experience.
Wishing all the forum members, Admin, Moderators, Readers.. a Happy new year.
Posted: Fri Jan 06, 2023 2:55 pm
by patil
Log#4
Direct TPMS:
I bought the full kit from AliExpress.
The Tiguan bracket was bought long ago when I installed direct tmps in my Polo6R but I didn't used it in my Polo. Now it will come handy in T-roc installation.
Also, I didn't install replica sensors from AliExpress(5Q0907275B). I bought newer version OEM sensors( 5Q0907275F) purchased from eBay. I will keep the AliExpress sensors as backup.
I bought MQB canbus adapter for tapping the Canbus lines for the installation.
Wiring scheme:
1) +30 from new fuse holder
2) Ground: Any near by ground point. I connected to ground hub near left tail light.
3) Canbus extented High&Low: Gateway adapter (T20,17/7)
Such an error will hang if we supply+15 instead of +30 to the TPMS module by mistake.
I simultaneously did the wiring for BSD radars, details of which I will share little later.
Posted: Wed Jan 18, 2023 7:25 pm
by patil
Log#5
Newer ODIS-E(14.1)/S(9.1) versions for VAS 6154 on Windows 11: Successfully installed!
Previously I had ODIS- E (9.0)/S(6.2) installed on Windows 7 for VAS 5054 clone. Newer and latest versions won't support VAS 5054.
To work with T-roc seamlessly, newer versions of both ODIS were required. I purchased ODIS- E(14.1) and ODIS-S(9.1) from different sellers, links below.
Both the sellers were sceptical about successfull installation on newer Windows 11, though they recommended to install on Windows 10. Because I didn't had Win10, I took a bit risk and went ahead with installation on Win11.
The installation of both newer versions of ODIS E&S didn't go smoothly, they will hang mid way during installation. But there is a trick to overcome the hurdle.
Tip: We need to kill reg.exe in task manager, when installation hangs and doesn't proceed further. After reg.exe is killed( need to do 2-3 times) installation resumes smoothly.
Everything seems to work correctly from checks and tests I did.
ODIS- E 14.1/ WIN11/ VAS 6154 clone:
ODIS-S 9.1/ WIN 11/ VAS6154 clone:
VX Manager: 1.8.9
VCP subscription renewed and installed latest version on Windows11: Works well
All is well... All green
Posted: Thu Jan 19, 2023 8:45 am
by giannis20vt
Great information about those programs. I appreciate it. Thank you.
I have to mention it . 23oC at 18th of January !!!! WoW.
Posted: Fri Jan 20, 2023 1:03 pm
by patil
giannis20vt wrote: βThu Jan 19, 2023 8:45 am
Tropical countries like us won't have harsher winters like yours., instead we have hot summers
Posted: Thu Jan 26, 2023 5:47 pm
by patil
Log#6
Helix PnP Subwoofer spare tyre mount type installed(000051419 B): A joy& disappointment.
I was very much disappointed for the way in which I received the helix subwoofer and programming dongle. Inspite of paying lot of money for such parts, shipping costs and import tax, I was disheartened to see damages which is totally unjustified and unacceptable.
The box was thrown mercilessly, I don't find any other logical reason to cause such an extent of damages. Sometimes, somethings are beyond our control and wishes.. have to accept and move on.
An otherwise beautiful glossy surface was scratched.
Programming dongle... I couldn't believe, but it still works!!!
Programming files in SD card. For T-roc it's number 26.
The extra adapters provided weren't necessary in my T-roc. For now, the power and ground is tapped from MIB quadlock. But later I will improvise the power supply with independent fuse from additional fuse holder and better ground point.
After installation:
The sound quality has significantly improved over the stock.
My sincere thanks to iichel for helping me source many parts includig Helix sub.
Posted: Thu Jan 26, 2023 5:57 pm
by iichel
Well done Patil. I hope you enjoy the improved sound and we learnt from the way we will send parts from now on.
Posted: Fri Jan 27, 2023 7:04 pm
by patil
iichel wrote: βThu Jan 26, 2023 5:57 pm
Thank you iichel.. the improvement in sound quality is worth the efforts of us both.
When I went to Post office to register a complaint about damaged parcel.. the post office head, rather she had a piece of advice for me.." Doctor( she knows me.. she happens to be my patient.. ) why you buy a car for which you can't source parts locally" !!!...l left the place without speaking a word
- 2 pin connector for warning Led lamps: 1J0973119(2 nos)
-BSD control unit Master: 2Q0 907 686B
-BSD control unit Slave: 2Q0 907 685B
-BSD bracket (Left) 2GA 907 455
-BSD bracket (Right) 2GA 907 456
-Hexagonal nut N91018901 (2 nos)
I bought the customised full set including wiring kit from AliExpress. Worked out cheaper than buying individual parts.
The actual kit had warning leds inbuilt within the side mirrors. But I opted for larger leds housed in mirror caps as I am used to such setup installed in my Polo6R with 5Q0 radars. The mirror caps I received were white coloured, I got them repainted like OEM to glossy black colour from my dealer.
Mirror caps came with led lamps already glued for water proofing.
Installation & Wiring:
My T-toc already has the 3 point mounting for BSD radar brackets on either sides from factory.
Wiring diagrams:
The ready made wiring harness from AliExpress is perfect with correct colour coded wires, terminals and length.
Wiring connections:
+15 -- from additional fuse box (7.5A fuse)
GND-- to dash panel metal frame
CAN bus extended low& high-- to Gateway adapter T20g/7,17
Warning lamps Rt(k304) & Lt(k303)-- wired according to WD above.
When I tried to code the BSD radars with VCDS, the VCDS was behaving weirdly, changing one bit in one byte was changing another bit in another byte automatically.
I decided to code the radars with ODIS-E, below is my coding.
Parametrisation: This was the most difficult part of my installation. I had requested the seller to parametrise the radars for T-roc, he obliged and sent me parametrised radars. When I checked with VCDS, I could see radars already parametrised.
But after completion of installation, I noticed that radars were not calibrating and throwing too many false positive warnings. It became immediately evident that the dataset was not correct for my T-roc or may belong to LHD T-roc or some other car model.
So the hunt for correct dataset began. I saw there is a folder containing bunch of datasets for 2Q0 'B' radars in VCP file management. But all the datasets were codenamed for different platforms without labels, may be to prevent piracy or hacking. And also these dataset are in different format, I didn't knew how to flash them to try. Here dear Master Ciclo came to my rescue and helped me how to flash these datasets, for which my heartfelt thanks to him.
So it was all trial and error method to find out the correct dataset for my T-roc. I started to flash one by one. Some datasets were accepted, but again failed to calibrate and threw too many false warnings. Some datasets were outrightly rejected with error in AID as well as with " invalid dataset" error in scan.
Finally after trying some 8-10 different datasets, below is the winning dataset for my T-roc RHD.
After flashing the correct dataset, radars got fully auto calibrated within 2 km of test drive! and to date, as I write this post, I haven't noticed a single false or missed warning!!! Rear Traffic Alert(RTA) also works perfectly. Master ciclo had said, you'll immediately appreciate the difference when you flash the correct dataset.. I couldn't have agreed more with him.
Additional note: It is also possible to parametrise the 2Q0 radars with online connection to VW servers.
Here are my few observations of 2Q0 BSD+ RTA radars and also in comparison with 5Q0 radars I have installed in my Polo6R:
- From my personal experience, I feel both 2Q0 "B" and 5Q0" B" radars have similar range of detection.
- 2Q0 radars have additional warning lamps brightness control menu in MIB.
- 2Q0 radars warning lamps blink 3 times when changing lane if vehicle is detected in blind spot area even if side indicators are not turned on. 5Q0 radar warning lamps only blink if indicators are turned ON.
- The more fast the approaching vehicle, more earlier the warning lamps turn ON in both 5Q0 and 2Q0 radars.
- With 2Q0 radars, when lane assist is active, if we try to change lane to the side of vehicle detected in radar range, steering wheel vibrates additional to resistance along with blinking warning lamp. May be 5Q0 radars also have this feature but limited on PQ25 Polo I guess due to incompatible steering column, abs pump etc..
- In 2Q0 radars, RTA works with warning beeps with additional visual display in MIB with yellow and red layout depending on the proximity of the moving vehicle. In addition to that auto brakes activates with warning display on Cluster(AID) in case of impending collision. I feel this autobraking by RTA is bit more aggressive, making loud noise, confusing us whether it was autobrake or a collision.
- RTA feature with 5Q0 radars on my Polo6R, only has visual warning in MIB, other features won't work due to incomplete hardware as I mentioned above.
Wednesday,28,December,2022,23:09:44:09269
VCDS Version: 22.10.0.1 (x64) HEX-V2 CB: 0.4623.4
Data version: 20221026 DS344.0
www.Ross-Tech.com
VIN: WVGZZZA1ZLVTROoCK License Plate:
Chassis Type: A1-VW27 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 2B 3C 42 44 4B 52 5F 65 75
A5 BB BC CA D6 D7
VIN: WVGZZZA1ZLVTROoCK Mileage: 21184km-13163miles
05-Acc/Start Auth. -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
75-Telematics -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-DPCA) Labels:. 04E-907-309-V1.clb
Part No SW: 05E 906 018 AT HW: 05E 907 309 H
Component: R4 1.5l TFS H20 9640
Revision: 8AH20000 CVN: 5E8A0C2D
Coding: 012500322304190830000000000000000000000000000000
Shop #: WSC 00020 043 00000
ASAM Dataset: EV_ECM15TFS01105E906018AT 003003
ROD: EV_ECM15TFS01105E906018AT_003.rod
VCID: 77A8E2A6DF4F07E3DA8-8022
VINID: 9E65EAAAA441A9C9801C720314E84F2DE4
Readiness: 0000 0000
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 050 J HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 1911
Revision: 00005009 Serial number: CU501911185682 CVN: ABB5E1C0
Coding: 0014
Shop #: WSC 17734 418 534600
ASAM Dataset: EV_TCMDQ200021 001001
ROD: EV_TCMDQ200021_VW27.rod
VCID: 3C223D8AA6E9E4BBF7A-8068
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 5Q0 614 517 DK HW: 5Q0 614 517 BN
Component: ESC H35 0113
Revision: 00000000 Serial number: 63139000003538
Coding: 46FA8A7D90272473477F060362C82562510924E26046A4733022F00852A24B0B00000523525212121035351919323200
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Brake1UDSContiMK100IPB 049012
ROD: EV_Brake1UDSContiMK100IPB_049_VW27.rod
VCID: 7DA4F08EFD732DB3804-8028
Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb
Part No SW: 3Q0 959 435 N HW: 3Q0 959 435 N
Component: VWKESSYMQB 037 1307
Revision: 00037000 Serial number: 0534174099
Coding: 132C0C0723
Shop #: WSC 00020 999 00000
ASAM Dataset: EV_KessyHellaMQBAB 004052
ROD: EV_KessyHellaMQBAB.rod
VCID: 45D4586ED523A573984-8010
Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb
Part No SW: 5G0 907 044 FQ HW: 5G0 907 044 FQ
Component: Climatronic H04 2401
Revision: 00001K10
Coding: 061200242001100D1105004012101836
Shop #: WSC 00020 999 12345
ASAM Dataset: EV_ACClimaBHBVW37X 006151
ROD: EV_ACClimaBHBVW37X_006_VW27.rod
VCID: 7BA0FE96E3672383BE0-802E
Fresh air blower control module (front):
A/C pressure/coolant temperature sensor:
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 084 DG HW: 5Q0 937 084 CF
Component: BCM MQBAB M+ H42 0312
Serial number: 02001932500097
ASAM Dataset: EV_BCMMQB 020001
ROD: EV_BCMBOSCH_020_VW27.rod
VCID: 005A897A8A81405BEB2-8054
Rain/Light Recognition Sensor:
Subsystem 1 - Part No SW: 5Q0 955 547 C HW: 5Q0 955 547 C Labels: 5Q0-955-547.CLB
Component: RLHS 051 0206
Serial number: S6Y19M10D15H05M19S28
Coding: 0018DD
Anti-theft alarm system sensor:
Subsystem 2 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 005 0316
Serial number: 000000000ZY192950M1T
Alarm horn:
Subsystem 3 - Part No SW: 5Q0 951 605 B HW: 5Q0 951 605 B
Component: Sirene, DWA 004 0007
Serial number: 00000000000000754028
Steering Column Switch:
Subsystem 4 - Part No SW: 5Q1 953 521 Q HW: 5Q1 953 569
Component: Lenks.Modul H03 0170
Serial number: 0100221120190C400340
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb
Part No SW: 5QA 919 294 G HW: 5QA 919 294
Component: PDC 8 Kanal H08 0061
Serial number: 000150058419329
Coding: 0471155011
ASAM Dataset: EV_EPHVA18AU3700000 009046
ROD: EV_EPHVA18AU3700000_009_VW27.rod
VCID: 50FA793A1A6170DB3B2-8004
Address 13: Auto Dist. Reg (J428) Labels:| 2Q0-907-572.clb
Part No SW: 2Q0 907 572 R HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0372
Coding: 3204604218FF8748949C810500408500000000000000000004
ASAM Dataset: EV_ACCMRRCONTIVW376 003016
ROD: EV_ACCMRRCONTIVW376_003.rod
VCID: 43D04676DB179B43B60-8016
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 3Q0 959 655 CM HW: 3Q0 959 655 CM
Component: Airbag VW21 006 0720
Revision: -------- Serial number: 003Z2PPMRKF2
Coding: 88CCC0C0000000005C5400CF008840000065
ASAM Dataset: EV_AirbaVW21TS6VW48X 001014
ROD: EV_AirbaVW21TS6VW48X_VW27.rod
VCID: 0B40AE56B3C713038E0-805E
Subsystem 1 - Part No SW: ----------- HW: 454 002 910 19
Component: SideSensor_Df 008 0887
Serial number: 357000000004A1316142
Coding: 2D2D2D
Subsystem 2 - Part No SW: ----------- HW: 454 002 810 19
Component: SideSensor_Pf 008 0887
Serial number: 35800000000C98B8424V
Coding: 2D2D2D
Subsystem 3 - Part No SW: ----------- HW: 454 802 210 19
Component: SideSensor_Dr 301 0148
Serial number: 35100A0CB121A000000D
Coding: 2D2D2D
Subsystem 4 - Part No SW: ----------- HW: 454 802 510 19
Component: SideSensor_Pr 301 0148
Serial number: 35200E4A8381A000000P
Coding: 2D2D2D
Subsystem 5 - Part No SW: ----------- HW: 454 802 310 19
Component: FrontSensor_D 304 0149
Serial number: 35500964D2C1A000000R
Coding: 2D2D2D
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 17A 920 790 B HW: 17A 920 790 B
Component: KOMBI 503 4310
Coding: 65BC00986A88080C0188370F1001000000000906
ASAM Dataset: EV_DashBoardVDDMQBA0 001042
ROD: EV_DashBoardVDDMQBA0_001_VW27.rod
VCID: 2616FFE248654E6BB1E-8072
Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 AC HW: 3Q0 907 530 C
Component: GW MQB High 442 4388
Revision: -------- Serial number: 0000427114
Coding: 030100046F08560023100248180F00010001070000000000000000000000
GVL: 014E3C000000060040CC80008000C80010000000000200000000000000000000
ASAM Dataset: EV_GatewNF 013026
ROD: EV_GatewNF_VW27.rod
VCID: 70BAD9BABA2150DB1B2-8024
Generator:
Component: 5-01-14-01-04
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 5NA 959 442 HW: 5NA 959 442 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAT H06 0025
Serial number: 2601917550901873BZ2B
Coding: 250000
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Component: J367-BDMHella H10 9070
Serial number: 3250843205
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 2Q0 905 861 A HW: 2Q0 905 861 A
Component: ELV-MQBB H08 0021
Serial number: 19000332474005
Coding: 0800000000000000
ASAM Dataset: EV_ELVMarqMQBA0 002002
ROD: EV_ELVMarqMQBA0_VW27.rod
VCID: 313C1CBE71AB19D354C-8064
Address 3C: Lane Change (J1086) Labels:* None
Part No SW: 2Q0 907 686 B HW: 2Q0 907 686 B
Component: HRE3_Kl15_Mst H06 0150
Serial number: 14520011985865
Coding: 92A54640
ROD: EV_HREntryHellaGen3Kl15_002_VW27.rod
VCID: 392C249EA9DBD193ECC-806C
Lane change assistance control module 2:
Subsystem 1 - Part No SW: 2Q0 907 685 B HW: 2Q0 907 685 B
Component: HRE3_Kl15_Slv H06 0150
Serial number: 14520011913860
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q4 959 593 K HW: 5Q4 959 593 K
Component: TSG FS 007 0485
Serial number: 0000397175085
Coding: 00111220D001028000001000
ROD: EV_DCU2DriveSideMAXHCONT_VW27.rod
VCID: 4DC4604E0D535D33504-8018
Subsystem 1 - Part No SW: 5Q0 959 408 HW: 5Q0 959 164
Component: FOND_FHSG_DRV 007 0010
Serial number: 00000000000036110727
Coding: 1D0000
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 AB HW: 5Q0 909 144 AA
Component: EPS_MQB_ZFLS 131 1082
Coding: 151F0000
ROD: EV_SteerAssisMQB_015.rod
VCID: 74B2D5AACE396CFBFFA-8020
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 E HW: 3Q0 907 338 E
Component: FCM MQB Low 003 0367
Serial number: 17111910522941
Coding: 000000070900204600000900000000000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 003003
ROD: EV_MultiModulContiVW48X_003.rod
VCID: 372822A69FCFC7E31A8-8062
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q4 959 592 K HW: 5Q4 959 592 K
Component: TSG BFS 007 0485
Serial number: 0000396858048
Coding: 00111020DC01028000001000
ROD: EV_DCU2PasseSideMAXHCONT_VW27.rod
VCID: 4CC26D4AF649543B47A-8018
Subsystem 1 - Part No SW: 5Q0 959 407 HW: 5Q0 959 163
Component: FOND_FHSG_PSG 007 0010
Serial number: 00000000000036011483
Coding: 050000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 840 C HW: 3Q0 035 840 C
Component: MU-S--ER 724 0876
Serial number:
Coding: 02720600BE0000004111000100090A001F0500F60120040002
Shop #: WSC 12345 123 12345
ROD: EV_MUStd4CDELP_VW27.rod
VCID: 2B000ED6538773036E0-807E
Display and control head 1 for information electronics:
Subsystem 1 - Part No SW: 5G6 919 605 A HW: 5G6 919 605 A
Component: ABT_Std-2 H61 8214
Serial number: VWZ6ZJW3322738
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 5Q0 907 273 B HW: 5Q0 907 273
Component: RDKBERU30 H04 0009
Serial number: 30000000255241
ROD: EV_RDKBERU30_005.rod
VCID: 343215AA8EB92CFB3FA-8060
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5NA 035 284 C HW: 5NA 035 284 C
Component: OCULowMQBLGE H19 0825
Revision: --------
Coding: 02720601EA16380D3F1CBE000045400382E608
ASAM Dataset: EV_OCULowMQBLGE 004049
ROD: EV_OCULowMQBLGE_004_VW27.rod
VCID: 3D24308EBDF3EDB3C04-8068
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 L HW: 3Q0 980 654 A
Component: MQB_B_MFK H12 0610
Serial number: 15111915K10993
Coding: 0002070600000401000200568150A90084000E20002000
ASAM Dataset: EV_MFKBoschMQBB 002041
ROD: EV_MFKBoschMQBB_002.rod
VCID: 40DA497ACA01805BAB2-8014
Address BB: Door Rear Drv
Cannot be reached
Address BC: Door Rear Pass
Cannot be reached
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4K0 907 594 AC HW: 4K0 907 594
Component: SAD_STG_1 006 0002
Coding: 508040727602
ASAM Dataset: EV_SunRoofCONTIAU736 009011
ROD: EV_SunRoofCONTIAU736_009_VW27.rod
VCID: 75B4E8AEC54375F3C84-8020
Address D6: Light Ctrl Left 2 (A31) Labels: 7P5-941-591.clb
Part No SW: 7P5 941 591 AH HW: 7P5 941 591 A
Component: LED1L H07 0009
ASAM Dataset: EV_LED_PLUS_L_KEBODAVW416 001003
ROD: EV_LED_PLUS_L_KEBODAVW416.rod
VCID: 025E8372848D524BFD6-8056
Address D7: Light Ctrl Right 2 (A27) Labels: 7P5-941-591.clb
Component: LED1R H07 0009
ASAM Dataset: EV_LED_PLUS_R_KEBODAVW416 001003
ROD: EV_LED_PLUS_R_KEBODAVW416_VW27.rod
End----(Elapsed Time: 01:46, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
Some pictures and video demonstration of BSD+ RTA:
Video:
Posted: Mon Feb 13, 2023 1:36 am
by patil
Log#8
Sporty Aluminium pedals:
OEM A+B pedals: A gift from my friend Sheetal
Surprisingly cheap pricing from Skoda India.. 6β¬ for a set. VW India sells the same set with different part number for 35β¬!
First time seeing the OEM parts cheaper than replicas sold on AliExpress.
Footrest from AliExpress( RHD)... excellent quality and fits perfectly in my T-roc
