Polo 1.2 Tdi clutch tools
Posted: Fri Oct 14, 2022 10:38 pm
by unique one
Hello, I am looking at doing a clutch replacement on a 2013 Polo 6R 1.2 Tdi CFWA engine.
Does anyone know if the VW tools i.e. engine support 3300 A and forcing plate T10413 are required to complete a clutch replacement?
The manual states its required to push the against the sub-frame but does anyone know if its essential or if I could do it without them.
If anyone can shed a light that would be great.
Many thanks.
Re: Polo 1.2 Tdi clutch tools
Posted: Sat Oct 15, 2022 12:24 pm
by amer6R
You can always support the engine using an block of wood and a jack under the oil pan.
Im not sure for other tools, but the 1.6 TDI doesn't need it.
Posted: Sat Oct 15, 2022 6:42 pm
by unique one
Thank you very much for replying.
Any ideas whether this 1.2 TDI CWFA engine has a dual mass flywheel or a solid one?
There isn't any information available out there regarding it.
Posted: Sat Oct 15, 2022 7:27 pm
by amer6R
It has single mass flywheel. Clutch kit is cheap, if you want to save a bit money you can get Blueprint. Several of my friends are running them on 1.2tdi and they are ok.
Posted: Sat Oct 15, 2022 7:28 pm
by iichel
Vehicles with a start/stop system typically come with dual-mass flywheel.
Posted: Sun Oct 16, 2022 12:18 am
by unique one
As this is a Match model would it be fair to say the car will most likely have a single mass flywheel?
From what I know the Blue-motion model has stop/start capability only?
In terms of clutch manufacturers, how would Blueprint compare to Sach or Luk?
Posted: Sun Oct 16, 2022 2:16 pm
by amer6R
Sachs, Luk produce oem clutch parts for vw. If you dont mind spending extra get them.
From my expirience the Blueprint friction material is a little softer ( wears a bit quickly if you launch the car)
Posted: Mon Oct 17, 2022 11:25 am
by unique one
Thank you very much, appreciate it a lot!
Its an absolute pleasure to be part of this forum and to have wonderful people.
