Instrument cluster polo 6C
Posted: Fri Oct 21, 2022 9:20 pm
by bobby_tvl
Hello! I have a question, i have a vw polo 2015. I want to activate some functions on my IC like(range, oil temperature, consumptioj) and I don't have the lever with button on the wiper. If i put this steering wheel, i can have this functions? Thank you!
Re: Instrument cluster polo 6C
Posted: Sat Oct 22, 2022 5:24 am
by giannis20vt
Hello
This steering wheel is going to operate only if you have the correct BCM .
So you must check the BCM code. If your car has a BCM with code 6C0937089x or bigger number (6C0937090x) then it is OK, you can install a steering wheel with buttons.
If you car has a BCM with code 6C0937087x then you can't. You have to swap the BCM first with a new one , to program the BCM online and the to proceed with the steering wheel.
The is a easier way to have what you want; to swap the stalks from the steering column.
Take a look here:
viewtopic.php?t=76538
Posted: Sat Oct 22, 2022 7:40 pm
by bobby_tvl
giannis20vt wrote: Sat Oct 22, 2022 5:24 am Hello
Take a look here:
Thank you very much!
