Radio station logos
- Drives: Gti
Radio station logos
I just exchanged my 2019 Polo Gti+ for a new facelift Gti and must say the new one just feels that bit more ‘solid’ somehow. However…….I cannot figure out how to get all the DAB radio station logos to show up…..on my previous Gti you could manually upload any missing ones via an SD card but the new car does not have an SD card slot? Any ideas please?
Re: Radio station logos
Is this any help Peter ? > https://www.uk-polos.net/viewtopic.php?t=77578
Hi Peterpeterlewis321 wrote: ↑Sun Dec 04, 2022 9:40 am I just exchanged my 2019 Polo Gti+ for a new facelift Gti and must say the new one just feels that bit more ‘solid’ somehow. However…….I cannot figure out how to get all the DAB radio station logos to show up…..on my previous Gti you could manually upload any missing ones via an SD card but the new car does not have an SD card slot? Any ideas please?
I ran into the same problem on my facelift Polo also. As in the major station logos show up but some lesser stations do not show up. With the pre facelift Polo having the older MIB2 infotainment system the solution was to upload a missing station logo via an SD card. Since the SD slot no longer exists on the facelift Polo it’s a no go with the old method.
So, after research I found:
When VW moved from the MIB2 to the MIB3 infotainment setup in the facelift Polo they dropped that feature as it was a vulnerability in past platform like MIB2. It was used to get access to that units. So VW dropped features like POI, Map Update by SD and Radio Station updates.
So you are stuck with the station logo database preloaded at the factory...
In the VW manual for the facelift Polo it states the following:
Station logos
Station logos may be pre-installed for some frequency bands in the Infotainment system.
The station logos will be assigned to the stations automatically if Autoselect station logos is activated in the settings.
In Internet Radio mode, the Infotainment system accesses station logos from an online database and automatically assigns them to the stations.
Manually assigning station logos
You cannot assign station logos manually in the AM frequency band.
1. In radio mode, tap Station logos.
2. Select the station to which you wish to assign a station logo.
3. Select station logo.
4. Repeat the process for further stations if desired.
5. Tap to finish assigning station logos.
- Drives: Gti
Thanks for the replies-feared that may be the case….what a step backwards by VW!!!
