I own a VW Polo 1.6 TDI. I found out the timing was off limit using the "Camshaft adaptation intake bank 1 phase position" read from the measuring values. I assume the values for the threshold is +/-4.8. Here are the observed values from my car,
Engine off, Ignition on: 6.000°
Engine on: 6.375°
After timing kit replacement from OEM supplier (Continental AG)
Engine on: 6.000°
On both the conditions, the crankshaft speed was 780/min with warm engine. Is it normal to start with positive values and later move towards zero? Am I missing out on any adaptation? Or the timing needs to rechecked? I don't get any error codes on the autoscan. However, the idle seems a little bit rough and in slight inclines, the engine runs like it wants to stall at lower rpms. I've posted an autoscan for reference. Any leads would be helpful.
Thanks in advance.
Tuesday,14,March,2023,15:50:30:52737
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 23.3.0.0 (x64) HEX-V2 CB: 0.4630.4
Data version: 20230228 DS346.1
www.Ross-Tech.com
VIN: WVWC12604CT****** License Plate:
Mileage: 164510km-102221mi Repair Order:
Chassis Type: 60-VW25 (6N0)
Scan: 01 03 08 09 10 15 17 19 25 2E 44 56
VIN: WVWC12604CT042445 Mileage: 164510km-102221miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CLNA) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 NT HW: 03L 907 425 B
Component: 1,6l R4 CR td H33 9972
Revision: --H33--- Serial number: CVN: CC8F7658
Coding: 00110016030500080000
Shop #: WSC 00793 648 00255
ASAM Dataset: EV_ECM16TDI02103L906023NT 003013
ROD: EV_ECM16TDI02103L906023CR_003.rod
VCID: 05579D1445ADC6323C5-8050
VINID: 9E69D3042180113900102104144C3E95A0
Readiness: 0000 1000
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ABS82.clb
Part No SW: 6RF 907 379 A HW: 6R0 907 379 AB
Component: ABS8.2 front H03 0001
Revision: --------
Coding: 500200C1007100B40A2900E600D600000000
Shop #: WSC 02069 000 00000
VCID: 52FD7648C4A3A18AE97-8006
Part No SW: 6R0 907 044 J HW: 6R0 907 044 J
Component: Climatronic H11 0610
Revision: V0000000
VCID: 3A2D3EE87C5379CA017-806E
Part No SW: 6RU 937 086 B HW: 6RU 937 086
Component: BCM25 IM M+4 H46 0230
Revision: BY046001 Serial number: 0335 079123643
Coding: 3B904ABF08A10000003800003C0B94900000414F60040000200000000000
Shop #: WSC 124697 483 00190
VCID: 6099AC80BA4F431A6F3-8034
Subsystem 1 - Part No SW: 6R0 959 802 D HW: 6R0 959 802 D Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 002 3424
Coding: 010000
Subsystem 2 - Part No SW: 6R0 959 801 F HW: 6R0 959 801 F Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 002 3424
Coding: 010000
Subsystem 3 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H09 0013
Serial number: 0714243
Coding: 020000
Subsystem 4 - Part No SW: 6R0 959 811 E HW: 6R0 959 811 E
Component: J388__TSG_HL 002 3424
Coding: 020000
Subsystem 5 - Part No SW: 6R0 959 812 E HW: 6R0 959 812 E
Component: J389__TSG_HR 002 3424
Coding: 020000
Address 10: Park/Steer Assist (J446) Labels:| 6R0-919-475.clb
Part No SW: 6R0 919 475 C HW: 7E0 919 475
Component: PARKHILFE 4K H11 0013
Revision: -------- Serial number: 47301131800327
Coding: 108002
ROD: EV_VW250ParkiAssis2.rod
VCID: 3E2532F860FB55EA3DF-806A
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Component: VW10AirbagU06 H09 0020
Revision: -------- Serial number: 003GW009ZLF2 Dataset Number: v00300446RU 0001
Coding: 003036
Shop #: WSC 01383 785 00200
VCID: 49CF51242935E25298D-801C
Part No SW: 6RF 920 860 F HW: 6RF 920 860 F
Component: KOMBI H03 0103
Coding: 550800
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04120
VCID: 4DC76534DD5DFE72B45-8018
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6RU 937 086
Component: GW-K-CAN TP20 0230
Coding: 002300
VCID: 70B9DCC06AAFF39AFF3-8024
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H03 0103
Serial number:
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7661647425
Coding: 020000
VCID: 290FF1A489F5C25278D-807C
Address 44: Steering Assist (J792) Labels:* 6Rx-909-144-V1.clb
Part No SW: 6RF 909 144 J HW: 6RF 909 144 J
Component: EPS_ECU H26 0401
Dataset Number: 6RF074v____ 6010
Coding: 0000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_SteerAssisUDSNSK 005005
ROD: EV_SteerAssisUDSNSK.rod
VCID: 53F3734CFB79A882E21-8006
Part No SW: 6RF 035 187 C HW: 6RF 035 187 C
Component: Radio 557 5536
Revision: -------- Serial number: VWZ7Z2V9100247
Coding: 0E000400000010
Shop #: WSC 12345 123 12345
VCID: 49CF512429B5E25298D-801C
End----------(Elapsed Time: 01:06, VBatt start/end: 12.2V/12.2V)-----------
