Crank Position Sensor
Posted: Thu Mar 23, 2023 2:43 pm
Please help!! I am at the end of my tether and bank account.
1.2 TDI 2013
In December, I had the engine management light come on. After reading it, I had the fault code: P032200
I was advised to change the crankshaft sensor. Which was changed for an after market one. This didn't solve the issue. So it was replaced with a Bosch one. This didn't work, so I then replaced it with a genuine VW one along with the a genuine VW pick up ring.
I've still got the same fault and I've been advised to check the ECU. For some reason, then ECU cannot be cloned to a donor one as it can't be read and apparent I can't get a donor ECU programmed to the car.
Has anyone else got an ideas before the car has to be scrapped.
1.2 TDI 2013
