Polo 6C: emergency brake flashing
Posted: Tue Jun 27, 2023 8:38 pm
by Le_Combattant
Hey fox,
It's been a while I get my hand on a OBDeleven, and until now I very happy of what I can with this little device.
Fast coding, fast trouble shooting with diagnostic etc...
By the past, I've unlocked some option available for my 6C (end of 2014) and I would like to unlock/code the emergency brake flashing.
On the OBDelven their is the "one shot" option available or "click and go" but it doesn't seems to work (I only try at 50km/h or 30mph).
Did I something wrong or maybye I need to go faster (I heard 70km/h).
Re: Polo 6C: emergency brake flashing
Posted: Tue Jun 27, 2023 11:54 pm
by Bepis
When I wanted to figure out if I had emergency braking brake light flashing enabled I found a sufficient section of road with a fairly large road sign (preferably white and reflective) and once it was dark drove past it at 60mph (100kmh~) stood on the brakes and looked in my mirror to see the flashing light reflecting off the sign.
In my case, the lights didn't start flashing immediately, it took a good second, and when I came to a stop the hazard warning lights came on, and then turned themselves off when I pulled away.
I'd assume the car would need to see various things like a sudden and hard application of the brakes over a set amount of time, ABS/ESC intervention, and a certain speed.
Just for reference my car is a MY17 UK spec.
Posted: Wed Jun 28, 2023 6:07 am
by amer6R
hard braking that activates abs will make it flash
Posted: Wed Jun 28, 2023 6:38 am
by Le_Combattant
amer6R wrote: Wed Jun 28, 2023 6:07 am
It's by default on the 6C ?
To be honest I'm not hard breaking every days
Posted: Wed Jun 28, 2023 1:57 pm
by Le_Combattant
EDIT: After coding using the same way as for Golf 7, it's working fine.
Over 90 km/h with hard braking (ABS working) warning (hazard light) come on after the final stop.
Posted: Wed Jun 28, 2023 8:37 pm
by amer6R
i think it should, its a safety feature on most cars
Posted: Wed Jun 28, 2023 8:45 pm
by Le_Combattant
amer6R wrote: Wed Jun 28, 2023 8:37 pm
It's seems it was not activated. But now, it is
Posted: Wed Jun 28, 2023 9:03 pm
by iichel
What coding / adaptation did you use?
Posted: Thu Jun 29, 2023 7:00 am
by Le_Combattant
iichel wrote: Wed Jun 28, 2023 9:03 pm
This one:
High intensity brake light (hazards flash with hard braking)
09 - Central Electronics
Adaptation - 10
(1)-Assistance light functions-Notbremsanzeige NBA -> "active" (default "not active")
(11)-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2 -> "active"
(15)-Dyn. turn signal modes-Crashblinken -> "active"
