Posted: Mon Jul 24, 2023 3:22 pm
by Glen22rp
Re: Radio upgrade for RCD310
Posted: Tue Jul 25, 2023 10:06 am
by RUM4MO
I think that, in case that you do not know, the pre-facelift 6R Polo is quite different to the facelifted 6C Polo, so don't assume that you can buy one from the facelifted models.
I think that people have been buying in a Chinese made bit of kit from AliExpress etc.
Have you tried using the "search" function, most search functions in motoring, at least, forums are extremely fussy so interest can be lost quickly and replaced with frustration!
Good luck, hopefully someone will come to your aid with good practical advice!
Posted: Sun Jul 30, 2023 8:44 pm
by crazy4alfa
I think RCD330 works.
Posted: Sun Jul 30, 2023 9:16 pm
by Soy2
I did the upgrade with my RCD310 to a touchscreen sony system with apply car play and andriod auto. The only thing i needed was a wiring harness adapter. The biggest problem i came across with this aftermarket upgrade was the powering of the new unit. I left the car for 2 days and it drained the battery dead. I had to wire the continuous power wire to piggy-back from a fuse which switch off/on with ignition. Wasnt too complicated. Can go into more detail if you go this route.
In therms of parking sensors, i have the same ones. My headunit supports it but i wasnt bothered to set it up.
Posted: Tue Aug 01, 2023 6:01 pm
by ciclo
If you are looking for functionality, you don't mind sharing data on the network (for navigation, etc) and that the new radio can be diagnosed, the RCD440 PRO will do perfectly.
Plug & Play with the correct harness and radio antenna cable for the conversion, the battery will not drain.
It is a radio for Chinese VW cars and many other places in the world. You can buy it on Ali, eBay, amazon, etc...
With a search on Ali you find everything you need to know.
There are installation tutorials on the Indian and Russian forums, and I also seem to remember that there are tutorials on youtube.
