Short throw shifter for 5-speed Polo 6c
Posted: Wed Aug 02, 2023 12:55 pm
Hi everyone, I'm looking for some advice related to short throw shifters for 6R/6C Polos with a 5-speed manual gearbox (and 1.2 TSI engines with code CJxx if that changes things).
As far as my research went, the 6-speed is MQ 200-6 and the 5-speed uses the MQ 200-5.
While was able to find some short shifters for the 6-speed gearbox which reduce both front-back and side-to-side movement, I'm coming across conflicting info for the 5-speed.
As far as I can tell, this Forge quickshifter
FMVAG5QS - https://www.forgemotorsport.com/Quicksh ... --997.html
only reduces the front-back movement which would be fine for me since I currently have such short shift solution installed in a different (non-VAG) car.
(some of the fancier 6-speed short shifters have 2 parts and also reduce the side-side movement).
Forge does not mention compatibility with 6R/6C 5-speeds, but this seller does
https://www.bar-tek-tuning.com/quickshi ... e-fmvag5qs
I also found this one
https://creationsmotorsport.com/index.p ... shift.html
so I'm curious whether someone has any experience or is using any of the available 5-speed short shifters.
Thanks!
Thanks!
