Polo 1.2TSi 7DSG Long coding
Posted: Mon Jan 15, 2024 5:09 pm
Hello everyone!
My name is Vedant and I have an Indian spec 1.2 TSi 7DSG Polo! I recently replaced my clockspring with a used one as my original one short circuited during some other retrofits. How ever after installing the used clockspring and copying the long coding over, the car Traction light refuses to go away! I tried following all basic adaptation procedures for the steering angle sensor, but it always stops at aborted due to safety reasons. The ABS unit also has a fault code that says it cannot function due to a coding error in another module which i think is the steering angle sensor. I will be posting the auto scan for my car below, so I would request if someone can help me figure out the long coding for the ABS Unit and the Steering angle sensor! The autoscan should provide you with all the data you need! You can ignore the Airbag, Radio, and Transmission errors can be ignored as I'm already working on fixing the wheel speed sensor.
VIN: MEXL15600GT047804 License Plate:
Mileage: 61560km-38251mi Repair Order:
Chassis Type: 60-VW25 (6RU)
Scan: 01 02 03 04 08 09 15 17 19 25 44 56
VIN: MEXL15600GT047804 Mileage: 61560km-38251miles
02-Auto Trans -- Status: Malfunction 0010
Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 KC HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 6270
Revision: --H10--- Serial number: CVN: A3186598
Coding: 00250056232400080000
Shop #: WSC 01234 785 00200
ASAM Dataset: EV_ECM12TFS02103F906070KC 004006
VCID: 6D87C9A91D1200B2F45-8038
VINID: 755A1C04518001790010720010EE8A83E2
Readiness: 0010 0000
Part No SW: 0AM 300 041 D HW: 0AM 927 769 F
Component: GSG DQ200G2_PQ 050 2602
Revision: 00005008 Serial number: CU501807275055
Coding: 0000020
Shop #: WSC 00642 210 45725
VCID: 2A0D02B5E0FCD78A517-807E
1 Fault Found:
006279 - Wheel-Speed Signal from ABS Control Module
P1887 - 000 - Implausible Signal
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 96
Reset counter: 10
Mileage: 61329 km
Time Indication: 0
Date: 2021.11.14
Time: 18:58:04
Part No SW: 6R0 907 379 BN HW: 6R0 907 379 AS
Component: ESP9.0i front H03 0001
Serial number: --------------
Coding: 62DD2463422703C7461C24694255C0800908
VCID: 0B43A73103C6AE824A1-805E
4 Faults Found:
0990 - Steering angle sensor
B1168 54 [10001001] - Missing Calibration / Basic Setting
Fault Priority: 2
Fault Frequency: 1
Reset counter: 17
Mileage: 61563 km
Date: 2021.11.24
Time: 07:22:30
0993 - Steering angle sensor
Fault Priority: 2
Fault Frequency: 1
Reset counter: 17
Mileage: 61563 km
Date: 2021.11.24
Time: 07:20:42
0384 - Rear Right Wheel Speed Sensor
C101D 01 [10001001] - Electrical Failure
Fault Priority: 2
Fault Frequency: 1
Reset counter: 17
Mileage: 61563 km
Date: 2021.11.24
Time: 07:20:42
0395 - Rear Right Wheel Speed Sensor
C101D 01 [10000001] - Electrical Failure
MIL ON - Not Confirmed - Tested Since Memory Clear
Serial number: 09071713470352
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5FEE540748B2A5DF-802A
1 Fault Found:
1140736 - Steering angle sensor
B1168 07 [00001001] - Mechanical Failure
Fault Priority: 2
Fault Frequency: 136
Reset counter: 16
Mileage: 61101 km
Date: 2021.11.08
Time: 17:40:07
Voltage terminal 15: 13.40 V
Voltage terminal 30: 13.90 V
Terminal 15 status: On
Part No SW: 6R0 907 044 Q HW: 6R0 907 044 Q
Component: Climatronic H12 0615
Revision: V0000000
VCID: 41DF4519718A34D260D-8014
Part No SW: 6RU 937 087 M HW: 6RU 937 087
Component: BCM IM H+4 H40 0432
Revision: BZ040001 Serial number: 0300 294150025
Coding: 7AB02FF808A10000003820007F2B949000C0004F608C0040200000000000
Shop #: WSC 12345 123 61029
VCID: 6C81C4AD268809BAE3B-8038
Subsystem 1 - Part No SW: 6R0 959 802 CC HW: 6R0 959 802 CC Labels: 6R0-959-802.CLB
Component: ------------- 007 5551
Serial number: 13202670150723011434
Coding: 050000
Subsystem 2 - Part No SW: 6R0 959 801 BT HW: 6R0 959 801 BT Labels: 6R0-959-801.CLB
Serial number: 13202671150811210237
Coding: 050000
Subsystem 3 - Part No SW: 6R0 959 811 L HW: 6R0 959 811 L
Component: ------------- 006 5550
Serial number: 13102580150623201032
Coding: 020000
Subsystem 4 - Part No SW: 6R0 959 812 L HW: 6R0 959 812 L
Serial number: 13102581150809000647
Coding: 020000
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW010RXK3 Dataset Number: v00300446RU 0001
Coding: 003036
Shop #: WSC 00000 938 41592
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 49CF5D39493AFC92B8D-801C
1 Fault Found:
9437211 - Igniter for Driver's Airbag
B1000 1B [10001001] - Resistance Too High
Fault Priority: 2
Fault Frequency: 1
Mileage: 61327 km
Date: 2021.11.14
Time: 17:40:09
Part No SW: 6RF 920 861 HW: 6RF 920 861
Component: KOMBI H01 0214
Coding: 5308000000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
VCID: 0849983D12B0C59A673-805C
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-19.clb
Part No SW: 6RU 909 901 HW: 6RU 937 087
Component: GW-K-CAN TP20 H40 0432
Revision: BZ040001
Coding: 002300
VCID: 196FCD79B99A4C12C8D-804C
Component: IMMO H01 0214
Serial number:
VCID: 6A8DC2B52CFC178A917-803E
Address 44: Steering Assist (J500) Labels:| 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
Component: EPS_ECU H61 1702
Dataset Number: 6RF074v____ 0118
Coding: 0001000000000000
ROD: EV_SteerAssisNSK_014_VW12.rod
VCID: 41DF4519710A34D260D-8014
1 Fault Found:
0231 - Function Restriction due to Faults in Other Modules
U1113 00 [00001001] - -
[Error value monitoring mBremse_3 Message]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 16
Mileage: 61563 km
Date: 2021.11.24
Time: 07:05:07
Voltage terminal 15: 13.507 V
Voltage terminal 30: 14.137 V
Engine RPM: 651.00 /min
Vehicle speed: 0 km/h
Status: Release
Part No SW: 6RD 035 187 A HW: 6RD 035 187 A
Component: MIB2-S-R-CN 025 0210
Revision: -----001 Serial number: 09845GD0072029
Coding: 00000400040001
VCID: 45D7510965A218F25C5-8010
4 Faults Found:
00876 - Treble Speaker Rear Left (R14)
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 250
Mileage: 61327 km
Time Indication: 0
Date: 2021.11.14
Time: 17:40:13
00875 - Treble Speaker Front Right (R22)
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 250
Mileage: 61327 km
Time Indication: 0
Date: 2021.11.14
Time: 17:40:13
00874 - Treble Speaker Front Left (R20)
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 250
Mileage: 61327 km
Time Indication: 0
Date: 2021.11.14
Time: 17:40:13
00870 - Bass Speaker Front Left (R21)
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 250
Mileage: 61327 km
Time Indication: 0
Date: 2021.11.14
Time: 17:40:13
End----------(Elapsed Time: 01:01, VBatt start/end: 13.7V/13.6V)-----------
Coding: 0000020
1 Fault Found:
Fault Priority: 0
Fault Frequency: 96
Reset counter: 10
Mileage: 61329 km
Time Indication: 0
Date: 2021.11.14
Time: 18:58:04
4 Faults Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 17
Mileage: 61563 km
Date: 2021.11.24
Time: 07:22:30
Fault Priority: 2
Fault Frequency: 1
Reset counter: 17
Mileage: 61563 km
Date: 2021.11.24
Time: 07:20:42
Fault Priority: 2
Fault Frequency: 1
Reset counter: 17
Mileage: 61563 km
Date: 2021.11.24
Time: 07:20:42
Coding: 01
1 Fault Found:
Fault Priority: 2
Reset counter: 16
Mileage: 61101 km
Date: 2021.11.08
Time: 17:40:07
Revision: V0000000
Coding: 050000
Coding: 050000
Coding: 020000
Coding: 020000
Coding: 003036
1 Fault Found:
Fault Priority: 2
Fault Frequency: 1
Mileage: 61327 km
Date: 2021.11.14
Time: 17:40:09
Coding: 5308000000
Revision: BZ040001
Coding: 002300
Serial number:
1 Fault Found:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 16
Mileage: 61563 km
Date: 2021.11.24
Time: 07:05:07
Status: Release
4 Faults Found:
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 250
Mileage: 61327 km
Time Indication: 0
Date: 2021.11.14
Time: 17:40:13
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 250
Mileage: 61327 km
Time Indication: 0
Date: 2021.11.14
Time: 17:40:13
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 250
Mileage: 61327 km
Time Indication: 0
Date: 2021.11.14
Time: 17:40:13
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 250
Mileage: 61327 km
Time Indication: 0
Date: 2021.11.14
Time: 17:40:13
