EPC waring light
Posted: Tue Jun 04, 2024 6:56 pm
by scotspie501
Hi
Does anyone have a idea what would bring on a EPC light on a polo 9N
Re: EPC waring light
Posted: Tue Jun 04, 2024 8:19 pm
by Maarten
usually brakelightswitch.
are your brakelights working?
You could also do a diagnostics scan of the car with ie obd11, carly or vcds
Posted: Wed Jun 05, 2024 10:01 am
by RUM4MO
Unfortunately, as said above.
If it is a brake light switch failure, try to get the revised design version.
Though, again as said in the above posting, lots of other possibilities so guessing is not a good idea.
Posted: Sat Jun 08, 2024 8:33 am
by littlepolo
It could be anything from an A/C issue to misfire detected on one of the cylinders, or indeed the brake light switch. A cheap code reader will help find the DTC(s) and you can take it from there. My old 2002 occasionally sets a DTC but I know it well enough to ignore them and let the lamp reset.
Posted: Thu Aug 22, 2024 9:13 pm
by scotspie501
all codes cleared now what a great site
