Fault code 03431 - Activation of left parking light Open circuit
Posted: Mon Aug 12, 2024 5:18 pm
Been a long time since I've posted here, but I still have my Polo!
I've recently run into some strange issues after removing and reinstalling the rear lights to do some cleaning behind the lights. I have done this a couple of times before while owning this car. Every time that I do this it has resulted in a fault code, and I have always just plugged in my OBDeleven and cleared the fault code and everything has been fine after that. But this time it's different. The "03431 - Activation of left parking light Open circuit" fault code keeps reappearing after I reset it.
It sounds obvious: "if the open circuit code keeps popping up after reinstalling the rear light, obviously the light isn't plugged in properly, duh". But the light is plugged in (I have unplugged it and plugged it back in properly to make sure). And the light turns on and stays on as it should, I have tried shaking and knocking on the rear light, pushing on the connector, slightly flexing the cable etc. while the light is on to try and see if there is a loose connection. I am not able to provoke a loose connection, the connection seems to be solid and the light stays on. But still, when I drive the car the warning light in the dash will come on within a couple of minutes/kilometers, even when driving on smooth roads.
Another strange thing is the circumstances when the warning light comes on. I have found is that if I run with driving lights on (light switch set to dipped beam, which means that rear lights are ON) then I will NOT get the warning light in the dash while driving. However if I run with with the driving lights off (which means front DRL is ON, rear lights are OFF) then the warning light will come on within a couple of minutes/kilometers. This seems really odd to me, that the diagnostics are detecting the light circuit to be open while the rear lights are not even turned on.
I would very much appreciate some advice, this is driving me crazy!
Here is a fresh readout done today using OBDeleven:
09 Central Electrics
System description: BCM PQ25 Max4
Software number: 7H0937090B
Software version: 0712
Hardware number: 7H0937090
Hardware version: H74
Serial number: 0571 245130969
Long coding: 24B029BF08E1240093280F9176EB87D15AC0672F600D30C1200000030000
Subsystems:
System description: RLS 070813 05
Software number: 1K0955559AH
Software version: 0403
Hardware version: 54
Long coding: 07302D
System description: J386__TSG_FT
Software number: 6R0959801AT
Software version: 8620
Hardware version: 003
Serial number: KU0KU023081300012257
Long coding: 0000A0
System description: J387__TSG_BT
Software number: 6R0959802BE
Serial number: KU0KU024081300011552
Long coding: 1000A0
System description: DWA-Sensor 00
Software number: 1K8951171A
Software version: 0103
Hardware version: 001
Long coding: 000000
System description: LIN BACKUP HO
Software number: 1K0951605C
Software version: 1501
Hardware version: H05
Long coding: 000000
Long coding: 000000
System description: E221__MFL-TAS
Software number: 5K0959542C
Software version: 0037
Hardware version: H31
Serial number: 0174508
Long coding: 820000
Trouble codes:
Intermittent
Priority: 2
Frequency counter: 254
Driving cycle: 82
Mileage: 141618 km
I am also confused about the "frequency counter" value, I've only ever seen the values 254 and 255. The "driving cycle" have been showing varying values in the 70-80 range.
The car has OEM Auto light switch retrofitted using a harness from ciclo here on this forum. Fantastic product, I have been running with it in this car for many years, and it has always worked 100%. I do not think it has anything to do with my issue, I am just mentioning it in case someone is wondering why the long coding looks the way it does.
Subsystems:
Long coding: 07302D
Long coding: 0000A0
Long coding: 1000A0
Long coding: 000000
Long coding: 000000
Long coding: 000000
Long coding: 820000
Trouble codes:
Intermittent
Priority: 2
Driving cycle: 82
Mileage: 141618 km
