Oil warning light problem
Posted: Wed Oct 01, 2025 6:46 am
Hey folks..
I have a 2007 1.2 Petrol BMD engine which has a brief orange oil light flashing on startup , maybe flashes 3 times then goes off…
Topdon scan shows error 00562:030 which refers to oil level thermal sensor G266, static open / short circuit ..
Problem is I don’t have a g266 sump pan sensor , nor do I have side level sensor in the case on timing chain.
I have changed oil pressure sensor in head ..
Still light flashes ..
I’ve not taken off the bonnet switch but it scanned on and off ok with top don..
Was planning an oil and filter change next , but I’m thrown by the sensor scan .. (oil level is fine btw)
So primarily my question is - why does it scan a sensor issue if sensor doesn’t exist ?
And ultimately how do I fix this ?
Could it indeed be a low oil pressure issue at startup (maybe oil or filter related) and the only signal the Topdon receives is the g266 reference…
Final note : Topdon outputs “ok” (think it’s only a on/off signal on these sensors rather than an actual value but I stand corrected) for oil pressure when live scanning but during this time the light isn’t on anyway so I guess it would say “ok”…
Sorry for the ramble but as I type this I think I’ve convinced myself it is indeed a low oil pressure at startup ??
Anyway - anyone experienced this mix of issues ?
Appreciate any feedback
