Intermittent dash outages and comms
Posted: Sun Feb 22, 2026 11:48 pm
Hi All,
Bought a 2016 1.0 polo tech pack recently. I had full electrical blackout whilst driving and start stop stopped working. It went back back under warranty. They diagnosed faulty battery and alternator.
We have had the car back a week and start sto now working but we are getting communication drop outs within first few mins of start up. Dash blanks, headlights blink, the dash cycles through abs, front bonnet, steering errors, and it settles on an orange triangle. Turn off and on after a few mins the triangle goes and faults may or may not recur during droving... My gut tells me my first issue was bad battery after sitting on the garage forecourt, could thd issues now seen be to due with the alternator replacement and disturbing any wiring? I dong have great faith in garages solving this type of issues, they dont have time to test and investigate.do if its easier for me to check loose connections that may have been disturbed I would ratger do that..before srmfing car back . any ideas?
John
Vcds scan is below:
Sunday,22,February,2026,22:42:15:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 25.3.0.3
Data version: 20250301 DS365.0
www.Ross-Tech.com
VIN: WVWZZZ6RZGU034686 License Plate:
Chassis Type: 6R-VW26 (6C0)
Scan: 01 03 08 09 15 17 19 44 5F
VIN: WVWZZZ6RZGU034686 Mileage: 75409km-46856miles
Address 01: Engine (J623-CHYA) Labels:. 04C-906-020-CHY.clb
Part No SW: 04C 906 057 HW: 04C 907 309 J
Component: R3 1.0l MPI H24 9076
Revision: 31H24000 CVN: 310CD98A
Coding: 01110052020401080000
Shop #: WSC 31414 790 50316
ASAM Dataset: EV_ECM10MPI01104C906057 001017
ROD: EV_ECM10MPI01104C906057_VW26.rod
VCID: 62CB1F8F754FB88BB6-8036
VINID: 9E69EAAAA1A2A979400C418818892E26B1
2 Faults Found:
4715 - No Communication with Instrument Cluster
U0155 00 [00100000] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Fault Priority: 2
Fault Frequency: 3
Mileage: 75257 km
Date: 2026.02.19
Time: 17:48:06
Engine speed: 1041.00 /min
Normed load value: 29.0 %
Vehicle speed: 0 km/h
Coolant temperature: 29 °C
Intake air temperature: 16 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 13.405 V
CAN status - engine control module-Bits 0-7: 0
selected gear-Bits 0-7: 0
4719 - Diagnostic Gateway
U0146 00 [00100000] - No Communications
Fault Priority: 2
Fault Frequency: 4
Mileage: 75197 km
Date: 2026.02.18
Time: 15:12:32
Readiness: 0000 0000
Part No SW: 6C0 907 379 K HW: 6R0 907 379 BA
Component: ESP9.0i H03 0004
Serial number: 08510184150918 Dataset Number: V03935226BE 0124
Coding: 23DD2485492633C4091A10710057C42492CC90080005CB098F00
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
ROD: EV_Brake1ESP90iBOSCHPQ26_VW26.rod
VCID: 377D9EDB8E4D8D2331-8062
Address 08: Auto HVAC (J301) Labels:| 6C0-820-045.clb
Part No SW: 6C0 820 045 A HW: 6C0 820 045 A
Component: AC Manuell H03 0108
Serial number: 1509071B-0942 Dataset Number: V03935228UR 0011
Coding: 200100001000100000
ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
ROD: EV_ACManueKMMValeoPQ26_VW26.rod
VCID: 1D316C730CB1C773CB-8048
Address 09: Cent. Elect. (J519) Labels:| 6C0-937-089-V1.clb
Part No SW: 6C0 937 089 D HW: 6C0 937 089
Component: BCM PQ26 Hi4R H08 0094
Serial number: 001588097178 Dataset Number: V03935258LA 0001
Coding: 03000840425300530FA44080B10703880000580257010000000000000000
Shop #: WSC 131071 1023 2097151
ASAM Dataset: EV_BCMA0 006002
ROD: EV_BCMA0_006_VW26.rod
VCID: 3169A0C3602953137F-8064
Driver door control module:
Subsystem 1 - Part No SW: 6R0 959 802 DK HW: 6R0 959 802 DK Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 003 0610
Serial number: KU0KU017091552607743
Coding: 1400A0
Front passenger door control module:
Subsystem 2 - Part No SW: 6R0 959 801 DH HW: 6R0 959 801 DH Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 003 0610
Serial number: KU0KU028091552714998
Coding: 0400A0
Anti-theft alarm system sensor:
Subsystem 3 - Part No SW: 6C0 951 171 HW: 5Q0 951 171
Component: Sensor, DWA 005 0316
Serial number: 000000000ZY152170HVC
Alarm horn:
Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000063604045
Subsystem 5 - Part No SW: 6R0 959 812 AA HW: 6R0 959 812 AA
Component: J389__TSG_HR 003 0610
Serial number: KU0KU024091552677524
Coding: 1400A0
Subsystem 6 - Part No SW: 6R0 959 811 AA HW: 6R0 959 811 AA
Component: J388__TSG_HL 003 0610
Serial number: KU0KU015091552585338
Coding: 0400A0
3 Faults Found:
12307 - License Plate Light
B12CA 01 [00001000] - Electrical Failure
Fault Priority: 2
Fault Frequency: 11
Reset counter: 119
Mileage: 75132 km
Date: 2026.02.17
Time: 17:12:29
Terminal 15 status: On
Terminal 50 status: OFF
Status Bremslichtschalter (HW): OFF
Status Bremslichtschalter (CAN): OFF
OFF: Not operated
Position lamps: operated
Automatic high beam assist: Not operated
Low beam: Not operated
Parking light left: Not operated
Parking light right: Not operated
Stoerschutzzaehler: 0
Voltage: 12.5 V
Outside temperature: 6.5 °C
262664 - Switch for Interior Monitoring / Inclination Sensor
B131B 29 [00001000] - Signal Implausible
Fault Priority: 4
Fault Frequency: 3
Reset counter: 119
Mileage: 75257 km
Date: 2026.02.19
Time: 17:48:36
OFF: Not operated
Position lamps: Not operated
Low beam: operated
Voltage: 13.4 V
Outside temperature: 8.5 °C
525838 - Limp Mode
C10CA 00 [00001001] - -
Fault Priority: 1
Fault Frequency: 1
Reset counter: 68
Mileage: 75257 km
Date: 2026.02.19
Time: 17:48:36
OFF: Not operated
Low beam: operated
Voltage: 13.3 V
Address 15: Airbags (J234) Labels:| 6C0-959-655.clb
Part No SW: 6C0 959 655 E HW: 6C0 959 655 E
Component: VW20Airbag00D 001 0360
Revision: -------- Serial number: 003RH005R5HF Dataset Number: V03935218YP 0343
Coding: 88C0C000000000005C000000008800000000
ASAM Dataset: EV_AirbaVW20BPAVW26X 001001
ROD: EV_AirbaVW20BPAVW26X.rod
VCID: 356194D394417F3323-8060
Subsystem 1 - Part No SW: ----------- HW: 410 822 309 15
Component: SideSensor_Df 151 0800
Serial number: 3575H00C31CFCD02809
Coding: 2D2D2D
Crash sensor for side airbag: passenger side:
Subsystem 2 - Part No SW: ----------- HW: 410 822 309 15
Component: SideSensor_Pf 151 0800
Serial number: 3585H00C31CFCD01404T
Coding: 2D2D2D
Subsystem 3 - Part No SW: ----------- HW: 442 150 605 15
Component: SideSensor_Dr 1CA 0148
Serial number: 3517A009919EACE4921Y
Coding: 2D2D2D
Subsystem 4 - Part No SW: ----------- HW: 442 152 709 15
Component: SideSensor_Pr 1CA 0148
Serial number: 3527A00A91C81BB041BK
Coding: 2D2D2D
Address 17: Instruments (J285) Labels:| 6C0-920-KOM-V1.clb-SRI3
Part No SW: 6C0 920 940 C HW: 6C0 920 940 C
Component: KOMBI 201 1420
Coding: 272409002180260001082A001000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009046
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
VCID: 244759972FDBF6BB84-8070
1 Fault Found:
1048578 - No Basic Setting
B2010 00 [00001001] - -
Fault Priority: 2
Fault Frequency: 1
Reset counter: 51
Mileage: 75057 km
Date: 2026.02.12
Time: 00:20:36
Address 19: CAN Gateway (J533) Labels:| 6C0-909-901-V1.clb
Part No SW: 6C0 909 901 A HW: 6C0 937 089
Component: GW MQB A0 H08 0094
Revision: -------- Serial number: 001588097178 Dataset Number: V03935009T0043
Coding: 030100046F0A640071000000000000010001010000000000000000000000
GVL: 01403C0000000000400000000000480000000000000000000000000000000000
ASAM Dataset: EV_GatewA0Lear 013020
ROD: EV_GatewA0Lear_013_VW26.rod
VCID: 2643439F59E704AB9A-8072
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 6C0 959 442 HW: 6C0 959 442 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAT H04 0019
Serial number: 2641510394200748AB2B
Coding: 240000
Subsystem 2 - Part No SW: 6C0 915 181 A HW: 6C0 915 181 A
Component: J367-BDM H08 0223
Serial number: 62272F43152821792984
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6C2 909 144 AG HW: 6C2 909 144 D
Component: EPS_TRW_ALow 322 3232
Serial number: CF9Q0164 Dataset Number: V03935224VJ 0548
Coding: 000700
ASAM Dataset: EV_SteerAssisUDSTRW 016026
ROD: EV_SteerAssisUDSTRW.rod
VCID: 6ED37BBFB1970CEB22-803A
1 Fault Found:
1068800 - Databus
U1121 00 [00001000] - Missing Message
Fault Priority: 6
Fault Frequency: 3
Reset counter: 119
Date: 2000.00.00
Time: 00:00:00
Engine speed: 1754 /min
Vehicle speed: 20.38 km/h
System status: Driving mode
Terminal 15 status: Terminal 15 on
Voltage terminal 30: 13.46 V
Power steering current consumption: 0.55 A
max.value: 10.91 A
End stage temperature: 17 °C
Steering assistance: engine output: 100.00 %
Engine angle: 32 °
Electric motor speed: -21 /min
Steering assistance: target engine torque: -0.10 Nm
Steering torque: 1.01 Nm
Status: OK
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 820 A HW: 3Q0 035 820 A
Component: MU-S-D-ER H24 0245
Serial number: VWZAZ2R8871658 Dataset Number: V03935223SB 0001
Coding: 02620000BE00000051111101008808001F0100C60120010001
ROD: EV_MUStd4CTSAT_VW26.rod
VCID: 275D4E9B5EED1DA3A1-8072
Display and control head 1 for information electronics:
Subsystem 1 - Part No SW: 6C0 919 603 HW: 6C0 919 603
Component: ABTm_Std2 H52 1028
Serial number: VWZ8Z9REU00Q6F
1 Fault Found:
0014 - Connection between Antenna Amp 1 for Digital Radio and Antenna
B1274 13 [00001001] - Open Circuit
Fault Priority: 6
Fault Frequency: 1
Reset counter: 51
Mileage: 75057 km
Date: 2026.02.12
Time: 00:20:41
Voltage terminal 30: 13.4 V
Status of digital radio antenna 1-Antenna current: 0 mA
Status of digital radio antenna 1-Connection between radio and antenna amplifier: electrically OK
Status of digital radio antenna 1-Connection between antenna amplifier and antenna: electrically OK
Status of digital radio antenna 1-DAB_Bit_Error_Rate_FIC: 0.000000
Status of digital radio antenna 1-DAB_Bit_Error_Rate_MSC: 0.000000
End-------------------------(Elapsed Time: 02:36)--------------------------
------------------------------8 Faults Found---------------
John
Vcds scan is below:
www.Ross-Tech.com
2 Faults Found:
Fault Priority: 2
Fault Frequency: 3
Mileage: 75257 km
Date: 2026.02.19
Time: 17:48:06
Fault Priority: 2
Fault Frequency: 4
Mileage: 75197 km
Date: 2026.02.18
Time: 15:12:32
Coding: 1400A0
Coding: 0400A0
Alarm horn:
Coding: 1400A0
Coding: 0400A0
3 Faults Found:
Fault Priority: 2
Fault Frequency: 11
Reset counter: 119
Mileage: 75132 km
Date: 2026.02.17
Time: 17:12:29
OFF: Not operated
Voltage: 12.5 V
Fault Priority: 4
Fault Frequency: 3
Reset counter: 119
Mileage: 75257 km
Date: 2026.02.19
Time: 17:48:36
OFF: Not operated
Low beam: operated
Voltage: 13.4 V
525838 - Limp Mode
Fault Priority: 1
Fault Frequency: 1
Reset counter: 68
Mileage: 75257 km
Date: 2026.02.19
Time: 17:48:36
OFF: Not operated
Low beam: operated
Voltage: 13.3 V
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
1 Fault Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 51
Mileage: 75057 km
Date: 2026.02.12
Time: 00:20:36
Coding: 240000
Coding: 000700
1 Fault Found:
1068800 - Databus
Fault Priority: 6
Fault Frequency: 3
Reset counter: 119
Date: 2000.00.00
Time: 00:00:00
max.value: 10.91 A
Engine angle: 32 °
Status: OK
1 Fault Found:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 51
Mileage: 75057 km
Date: 2026.02.12
Time: 00:20:41
