Antenna Adapter required 4 aftermarket HU for 9n?
Posted: Mon Oct 18, 2004 8:10 am
by carmadaaron
ive been told i need 1 or i wont get radio reception for an aftermarket HU.....
its this true? do i really need 1 for the 9n?
Aaron
Posted: Tue Oct 19, 2004 12:48 am
by sylonien
No that isn't true. I've got an aftermarket Alpine head-unit and it works fine and I've swapped my aerial for a shorter one.
The plug inside the dash for the aerial is a standard one so you don't need any adaptors as such. It
will work.
Posted: Tue Oct 19, 2004 1:30 am
by pukka
Think I'm right in saying you'll get better reception with an adaptor. Your 9n has an amplified antenna and needs to be powered up. The VW Beta, Gamma etc. headunits do this directly, but I think few aftermarket headunits do too(?)... hence the need for an adaptor (which nicks power from the ISO block on the aftermarket headunit).
It's autoleads part PC5-52 and about a tenner from Halfords (could always return it if you don't notice any difference
Posted: Tue Oct 19, 2004 9:40 am
by carmadaaron
so the woman in halfords was talking rubbish.....
well ill just leave it if the current 9n ariel plugs into the new head unit......
thx guys...
Posted: Tue Oct 19, 2004 10:28 am
by pukka
The adaptor isn't for connecting different heads/connections. The adaptor is to amplify the aerial on the 9n.
I have one installed on my 9n and reception is very very good... in fact, I never knew there where so many radio stations avaliable in my area
Posted: Tue Oct 19, 2004 12:46 pm
by Wheatley
I wouldn't believe anything Halfords have to say, they told me I needed 13cm rear speakers
Posted: Tue Oct 19, 2004 1:09 pm
by carmadaaron
is it 16cm for the rear doors?
Posted: Tue Oct 19, 2004 6:44 pm
by Wheatley
It's 16.5 (6.5") for the front and the rear.
You will need to buy the speaker adapters to fit on the doors, these can be found at
http://www.caraudiodirect.co.uk/default ... 92_319_637.
I have not tested these yet but will be buying very soon.
Posted: Wed Oct 20, 2004 10:35 am
by carmadaaron
can i make my own from MDF say..... and put smaller speakers in..? ie 13cm
Posted: Wed Oct 20, 2004 12:32 pm
by Wheatley
I don't see why not.
Why opt for the smaller speakers when you can have the 16.5cm?
Posted: Wed Oct 20, 2004 1:19 pm
by sylonien
'cos they're cheaper?
Posted: Thu Oct 21, 2004 10:35 am
by carmadaaron
i dont want to touch the front 1s (ie skint) so whats the point having amazing rear speakers and standard fronts?
Posted: Thu Oct 21, 2004 5:03 pm
by sylonien
But that's kinda what I'm thinking about right now!
'cos I want some sound from the back.
But really strangely enough, the bog standard VW 'Beta' components are still lasting very welll with my current system. It's pumping 60W to each channel, but it's still going very well up to around Volume18 (Alpine head-unit) and still sounds very good.
But then I did tune it quite a bit with the X-over, etc.
Quite good quality s**t. Not toooo much mid-range though. But at least the high-range (tweeter) kinda works.
Posted: Fri Oct 22, 2004 10:34 am
by carmadaaron
does any1 know the power rating of the standard beta speakers? cus i dont want sumthing too much bigger than the front 1s...
