UK-POLOS.NET - THE VW Polo Forum • gt to g40 brakes
gt to g40 brakes
Posted: Fri Nov 05, 2004 1:42 pm
by lord_sharpy
hi guys, what do i need to convert my gt standard discs to g40 vented ones, do discs off a mk1 golf etc fit?
cheers
james
Posted: Fri Nov 05, 2004 2:52 pm
by Karl_CLCoupe
I've got a set to fit to mine. I believe Mark1 Golf carriers and calipers fit, (or if you can find any calipers in a scrappy stamped with VW and Roman numerals II, they should fit). I'm not too sure on other carrier set-ups, but I hope thats of some help.
Karl.
Posted: Fri Nov 05, 2004 3:46 pm
by optima21
yeah I beleive you can use any VW II calipers for vented disks. I ended up using g40 calipers with the standard GT carriers and used the G40 sliding bolts and tubes. the gt ones should work ok though, but one is shorter than the g40 ones.
ohh heres the setup I used but ignore the disks as they are the wrong ones but still 20mm thick.
the mk1 golf gti/g40 brake pads are the same shape as the GT ones, just a bit thinner
Posted: Fri Nov 05, 2004 11:09 pm
by GroovyCarrot
Personally I have VWII calipers and carriers waiting to go on (when I can afford the discs and pads to match..). Don't know if the caliper fixings are the same on mk2/3 polos, but if they are then almost any mk2 golf gti, late mk1 golf gti, passat, scirrocco etc will be fitted with them, fair bit easier to track down than G40 calipers :)
Posted: Sat Nov 06, 2004 10:48 am
by pettsy
i think the mk2 golf calipers mount differently.
g40 brakes
Posted: Sat Nov 06, 2004 10:54 am
by lord_sharpy
cheers guys, so the calipers with 'II' written on it should bolt straight on with the carriers from the same donor car? then i just need to bolt the discs on?
Posted: Sat Nov 06, 2004 11:47 am
by optima21
no if its a golf etc the carriers have differentr mounting holes, so you need to use the carriers from the polo not the donor. then you just need the vented disks. you should get some new pads, but you could use your aold ones (although its not recommended)
Posted: Sun Nov 07, 2004 1:39 pm
by genesisGT
:D Hi I did this conversion on my 1043cc Polo which has the same vw type 1 brakes as all GT/non G40 mk2fs. I used the pad carriers, calipers, of a Scirroccco GTII as they are the same as a mk1 golf GTi and G40.
I would buy new front flexi hoses for the brakes when you are there as they are only about £6 a pair for standard ones. I got all the bits out the scrap yard for £25 (mounting bolts/calipers/padcarriers/old pads and disks.) A then traded in the old calipers as exchange items then bought new cross drilled and vented disks and fast road pads and just wire brushed the pad carriers. Its a worth while conversion as it improves your driving enjoyment no end even in the 1.0L! As a can now do the full (95mph and be able to stop before the end of the slip road!)
