UK-POLOS.NET - THE VW Polo Forum • Scraping noise from steering column
Posted: Mon Dec 27, 2004 6:04 pm
by James0121
Hey up
I was just wondering if anyone else has had this. When turning corners theres an irritating scraping sound it doesn’t effect steering but is getting on my nerves anyone know the solution before I sit down and dismantle it?
Slightly different topic the bump strips off a 6n2 will fit on a 6N once the stud things are cut off wont they?
Cheers James
Posted: Mon Dec 27, 2004 6:33 pm
by OGDMX
could just be a bit of dirt n crap behind ya wheel
just needs clean with a rag it'll be right...i got same prob i just havent been bothered to clean it
Posted: Mon Dec 27, 2004 6:37 pm
by James0121
awww well i guess i have known about it for a while but i have just been lazy to do anything about it
Posted: Tue Dec 28, 2004 10:28 am
by 13twelve
i'd had it a few times that scraping noise
and it just dissapears as quick as it appears
(but my steering colume thing broke one day - the adjustable height thing wouldnt lock and the wheel was bouncing - was hilarious and scary)
Posted: Tue Dec 28, 2004 10:54 am
by Speedlaw
As for your second question: Yes, they should.
Posted: Tue Jan 04, 2005 10:06 pm
by SpikeyG40
the scrapping noise is probably and more than likely the horn connection! these is a ring of brass on the steering collum, and on the back of ur steering wheel is a sorta springy pin! its those rubbing together as u turn the wheel!
remember i have been in ur car and i know the sound that u are talking about and i'm sure i told u this before!
u need to remove the steering wheel (not sure how), clean up the surfaces with some rag or summit and i used a bit of silicone grease to stop mine making noise! when i did that it got quieter and quieter as time went on and it has now gone i believe!
:lol:
Posted: Wed Jan 05, 2005 12:35 am
by Tahrey1043
only time i've had that, it was rubbing on the pedal box which was getting (imperceptably, at first) loose --- and snapped the next day
just give a peek in the footwell with a torch to make sure that aint the case
Posted: Wed Jan 05, 2005 8:08 am
by CalvinGTI
This happened to me !
Turned out the VW mechanic didnt re-grease the steering column after working on it, sounds like theve done the same to you !!!!
pretty lame if u ask me.
Calâ„¢
