Chips, chile sauce, sore finger
Has anyone compared hardhitter's and poloace's chips back-to-back?
Gareth_GT_Hatch
I've got a Superchip to add. Back to back with Dan's two of us feel that the Super has more top end, Dan's more mid, both are a noticeable improvement over std and well worthwhile. I'd love to have a set of rollers here to see if Dan's is the same top end but doesn't feel it as it's got more mid.
Can maps be scanned so they can be cut-and-pasted to get the best of all worlds? I have no idea of the terminology involved there, sorry
tainmrk3polo
- bstardchild
- Moderator
Superchips are normally a hack chip - basically they turn of the fuel over run cut off and borrow part of the cost start enrichment values (the choke settings) for the main fueling mapsnuttinnew wrote:I've got a Superchip to add. Back to back with Dan's two of us feel that the Super has more top end, Dan's more mid, both are a noticeable improvement over std and well worthwhile. I'd love to have a set of rollers here to see if Dan's is the same top end but doesn't feel it as it's got more mid.
- turn off fuel overun cut off and you'll get better pick up everytime you put you foot back on the throttle (but you will WASTE fuel)
- Cold start enrichment (choke settings) will help WOT (wide open throttle) ie fueling at top end (not the best way to do it IMHO)
To answer your question the maps aren't maps but bits and bites BUT you can take the info in it binary form and compare it taking the best of all and come to better all round chip
BUT - the hard part is getting the checksum right if the chip architecture uses one - this bit I don't know yet cos I still haven't found a AEX ECU to start playing with.... Arse!!!!
JM2pW
MK3 have no Check sum checking, MK4 do. There are quite a few tables within the eprom and only certain ones can be adjusted this iw where the experience is needed my maps originate from a German suppier that has all the code he sell RR setup. Nearly all after market chips are just tweaks of the original code and just ceratin variables- Rev limit- Idle speed altered and then the look up table which is a table of numbers which the ECU when then use to look up the different values to use depending on the engine sensor states. The ECU will integrate between these values to smooth out its response.
I am currently speaking with Dan get one of his chips to compare the maps, I would be interested in getting the Superchips eprom. The same maps will work differently on every car. Playing with the tables without a RR is very time consuming and not easy. I have made an adapter that allows me to trial 4 maps on my G40 ECu and I compared 2 of these at Stealth at the G40 rolling road and there was about 2bhp difference which is actauilly hard toe tell on the road. It is very easy to run to rich or lean and damage the engein ifg you are not careful.
The AEX is the 1.4 I will be getting code for these eventaully that should give improvements of 4-5bhp. The most difficult thing on the Mk4 is the fact that the eprom is surface mounted chip and specila equipment is required to avoid damageing surrounding componets on removal. If getting a replacement ECU you will need to ensure you get the same version as there are quite a few variations out there.
Many of the UK chip tuning garages are just modem dealers and do the same as I do buying the modified maps from about 2 or3 main companys in Europe that get old of every new model and they rechip them on a RR and then sell those maps on. I have access to a German modem dealer who can supply me code for about 10,000 different models.
- bstardchild
- Moderator
Look - I'm not blowing my own trumpet here and I DO NOT want to tread on anyone elses toes - I've developed a few chips for previous cars I've owned and they all work finenuttinnew wrote:That's it!
Got a few good breakers round here, I can try and source an ecu for you if you so desire?
but I have a 1.4 8V that is asmatic and want to change that - I've bought a spare engine and ripped it apart and apart from the small ports it should breathe a lot better than it does - it's in the maps and I'd like to change it and put the information in the UK-P public domain
an EPROM and carrier cost less than a quid even if I cover for my time the end result should be about £20 if I can sell 10
Someone must have an AEX ECU?
- bstardchild
- Moderator
But if you have the checksum location you can rewrite the checksum to equal the sum of the chip - then whatever you do isn't a compromise and will not bring on the engine management light....poloace wrote:MK3 have no Check sum checking, MK4 do. There are quite a few tables within the eprom and only certain ones can be adjusted this iw where the experience is needed my maps originate from a German suppier that has all the code he sell RR setup. Nearly all after market chips are just tweaks of the original code and just ceratin variables- Rev limit- Idle speed altered and then the look up table which is a table of numbers which the ECU when then use to look up the different values to use depending on the engine sensor states. The ECU will integrate between these values to smooth out its response.
Any chip is a tweak of the original code hell there is no point re-inventing the wheel but I have seen in a lot of std chips huge holes to pass emissions and noise regs that are basically strangling the engines output - once you have the 3D maps in front of you the bloody holes are obvious - fill em up and you get instant mid range - top end and WOT maps take a bit more work but it's not that hard
Once you have a carrier in the ECU it's all plug and play. I reckon the 1.4 8V with a good chip should be good for 70bhp plus
I'll prove it with the opportunity
yeah I did but didnt find any noticeable difference between them (on the raod dyno) but thats on my engine, with standard ignition advance and I think I was making less power than I should have anyway, but that might be because its an old engine etc.
still the chips could work differntly with different modifications too.
Summat else, summat that has bugged the hell out of me for years, is insurance companies and chipping. Ah, performance modification, more money please. What happened before chips/ecus were about? You took your car in for a service and that included tuning it, i.e. tweaking the fuelling and timing! Performance mod? No, just good general maintainance practice. Seethe, fume.
Don't forget that fitting a 32dmtr to you Polo2 1.3 isn't a performance mod either, it's a std replacement!
Should get me an older car again....
I agree with Nuttinew there about insurance, as you could tweak your old car and not be charged a chip is classed as a mod.
on most of my maps it is plugged holes with changes to top end. It is good fun probing the code. I have a good mate who is a Micro controller expert and he has nearly completyl reverse engineered teh G60 ECU which will allow us to use it as a custom ecu for a number of applications.
I'm not doubting your capabilities I was just adding my comments.
Its an addictive hobby
- bstardchild
- Moderator
poloace wrote:I agree with Nuttinew there about insurance, as you could tweak your old car and not be charged a chip is classed as a mod.
I've done similar but only to understand what all the maps do - I took a complete loom and ECU with all the sensors out of a car and built it up (compacted it) as a test rig - was then able to play with all the inputspoloace wrote:on most of my maps it is plugged holes with changes to top end. It is good fun probing the code. I have a good mate who is a Micro controller expert and he has nearly completyl reverse engineered teh G60 ECU which will allow us to use it as a custom ecu for a number of applications.
I can see that - no offence takenpoloace wrote:I'm not doubting your capabilities I was just adding my comments.
Very addictivepoloace wrote:Its an addictive hobby
