I have always hated my sidelights as they give off a yellow glow. So i decided to buy some zenon bulbs that give off a bright white with a blue tint. I read on here that its impossible to change the sidelights without removing the bumper. Well i managed to do it without removing the bumper and using a flathead screwdriver.
The main problem is that there isnt enough room to get a good purchase on the bulb socket. Some ppl advise you to tug on the wires but i would be more careful incase you break the wire.
I am i simply used a precision flathead screwdriver to get the socket out past it's retainer using a a lever action ( like opening a tin of paint ) This worked a treat. Fitted lights and tested before fitting them back!!!
Walaa!!! Done
It can be done!
Will post in DIY and i know i shoulda only posted it there but thought you's might wanna know. Can post pics if you's want
Sidelight Replacing - Without removing bumper!
Thanks, yeah they are 501 wedges. Plenty of them on ebay but i used the www.powerbulbs.co.uk . I would recommend buying silver vision side repeaters and you will get philips vision bulbs free!! Free P+P so i think its just under £14 (inv vat) And you get a 10% discount for being a member tho not sure how to claim it.
Hope it helps
Hope it helps
sidelights
any one got a pic of where the sidelights are taken out from ? It sounds well easy but would like instuctions to exactly tell what it is i am looking to touch!
The sidelights can be removed from the back of the light housing. Theres a black cover over the lights secured with a metal bar that can be pulled to one side then slip the cover out towards the centre of the engine.
Then its easy to just levy the bulb holder out using a small flat head screw driver.
Bulbs are just push in and play.
Hope it helps
No pics sadly
Hope it helps
No pics sadly
Hope it helps
No pics sadly
Hope it helps
No pics sadly
sidelights
Cheers I will give it a go this weekend!!!
