will they foul on lock???
who does the best lowering kits??
thanks
15's on a mk 2
- Moderator
is it a coupe or a squareback? i have 15x6.5 on my mk3 n i have a graunching noise when the suspension is at a low, i.e. in a downer on a bump! also it rubs on the suspension on one side at the rear, i have 3mm spacers on the back! with suspension mod i believe that the graunching would stop and a bit of modification to the rear suspension strut will cure the rear! if i were u i would go to somewhere where the buy alloys and see if they have a number or something to ring, i ordered some 15x7 alloys and i was told they wouldn't fit, lucky i didn't get them cause if i am having problems with my current alloys, i dread to think wot they would be like with the wider ones! hope this helps
kit
decent quality and ease of fitting and looks (of course )
cost also but dont mind paying if good qual
- Moderator
mines got 15s
i got a 84 coupe and its on 15s with i think 185/45r15 and my car has been droped 40 mm with gas shocks fine when just 2 peps are in it but full load rubs like crazy and aceleration and slowly going over bumps full lock is fine
