ciclo's Polo. R-line 1.2 TSI 90hp 119gr.
- Drives: 1.2TSI 105HP DSG7
Achso!. Noted.
But FYI, I've never get the coming home function work at all. I've tried switch of ignition, and pull the high beam stalk once, and nothing happen.
but will ofcoz try to do some research anyway!tq
After that, you have to open the driver's door. (I guess you do it this way)benzinkopf wrote: I've tried switch of ignition, and pull the high beam stalk once, and nothing happen.
PRCode: 8K0 = Without special headlight activation
PRCode: 8K1 = Separate daytime running lights
PRCode: 8K2 = Daytime driving light mode for urban driving
PRCode: 8K3 = Separate daytime running lights with low beam assistant and Coming Home feature
PRCode: 8K4 = Separate daytime running lights NAR
PRCode: 8K5 = Low beam assistant with Coming Home function NAR
PRCode: 8K6 = Separate daytime running lights and Coming Home function
PRCode: 8K7 = Automatic headlight activation
PRCode: 8K8 = Low beam assistant with Coming Home function
PRCode: 8K9 = Separate daytime running lights with low beam assistant and Coming Home function
- Mart!n-GTI-DK
- Platinum Member
- Drives: '14 Polo BlueGT
Startet my Bonnet strut project today.
Painted VW Candy White to match the car and look as OEM as possible
Excellent. Increasingly perfect.
We expect to see installed soon.
- Mart!n-GTI-DK
- Platinum Member
I'm just waiting for the gas strut to arrive.ciclo wrote:Excellent. Increasingly perfect.
But that gives the parts a chance to cure some more before I install them.
Better that way.
Today I cleaned the car and engine after a couple weeks of bad weather.
- Mart!n-GTI-DK
- Platinum Member
My engine bay really needs a GOOOOOOOOOOD cleaning...
But... Have done some manual labor today.
Good job Mart!n-GTI-DK.
What is the reference number of your gas strut?
- Mart!n-GTI-DK
- Platinum Member
I ended up buying an aftermarket strut. The OEM one was quite expensive.
damnn you high tax on cars and carparts in Denmark.
Would have tried to have painted the strut White to match the car obviously not the hydraulic shaft.
None the less.. Will be copying this soon! How much was this strut?
I got a strut from eurocarparts for £18. Works fine. Its designed for a vw mk4 golf bonnet
Super ciclo, savior of Polos, god of customization (no really, good work),
May I ask you for a small favor?
I know you are (more or less) an expert on coding etc.
The case is:
I'm working on retrofitting OEM xenon with 10 to 14 pin adapters.
The car is a 2011 Polo 1.2TDI bluemotion with start/stop.
It's not completely standard (for exampe OPS front/back and GTI tacho) in case that's relevant.
I am therefor looking for a coding that makes them work.
You probably need an autoscan which is attached:
Saturday,14,February,2015,16:37:54:65217
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WVWZZZ6RZBY123456 License Plate:
Chassis Type: 6R (6R0)
Scan: 01 03 08 09 10 15 17 19 25 2E 37 44 56 61 69 77
VIN: WVWZZZ6RZBY225654
56-Radio -- Status: OK 0000
69-Trailer -- Status: OK 0000
Address 01: Engine
Cannot be reached
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Revision: --------
Coding: 210224E3416F00B7842B24E782D500521300
Shop #: WSC 00788 648 00255
VCID: 8717035C32D37526559-80D2
Address 08: Auto HVAC (J301) Labels: 6R0-820-045.clb
Part No SW: 6R0 820 045 G HW: 6R0 820 045 G
Component: Man AC 02 0101
Revision: 0002S 02
VCID: 326102886DD1A08E527-8067
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 088 D HW: 6R0 937 088
Component: BCM PQ25 Re4 H46 0322
Revision: BU046001 Serial number: 0379 028111968
Coding: 3CB02BB808210000002809F07D2B9CD9DF80611F7EA60001A00000000000
VCID: 3F875BBCAE837DE6AD9-806A
Subsystem 1 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 007 1611
Coding: 58BC30
Subsystem 2 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 007 1611
Coding: 48BC30
Subsystem 3 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A
Component: E221__MFL-TAS H09 0013
Coding: 820000
Address 10: Park/Steer Assist (J446) Labels: 7E0-919-475.clb
Part No SW: 7E0 919 475 L HW: 7N0 919 475
Component: PARKHILFE 8K H06 0106
Revision: -------- Serial number: 28231422402620
Coding: 310001
Shop #: WSC 12345 123 12345
ROD: EV_VW75XParkAssis8K.rod
VCID: 3B7F2FACB29B61C6811-806E
Component: VW10Airbag022 H09 0020
Revision: -------- Serial number: 003GX00EPNH2
Coding: 003232
ROD: EV_AirbaVW10BPAVW250_VW24.rod
VCID: 4A917A68ED41C84E0A7-801F
Crash sensor for side airbag; driver side:
Serial number: 3575HRB40650BI7U48C8
Crash sensor for side airbag; passenger side:
Serial number: 3585HRB405J09RECEOUJ
Crash sensor for side airbag; rear driver side:
Serial number: 3515RRB405T0BTBEF9G7
Crash sensor for side airbag; rear passenger side:
Serial number: 3525RRB405R0BTBEKPFQ
Part No SW: 6R0 920 870 A HW: 6R0 920 870 A
Component: KOMBI H03 0505
Coding: 540A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
VCID: 336F078C9ACBA986591-8066
Address 19: CAN Gateway (J533) Labels: 6R0-907-530-V2.clb
Part No SW: 6R0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H38 0025
Revision: H38 Serial number: 040211F1003097
Coding: 2500C2
Shop #: WSC 00000 000 00000
VCID: 336F078C92CBA986591-8066
Address 25: Immobilizer (O334) Labels: None
Part No SW: 0K0 953 264 HW: 0K0 953 264
Component: LMMO % H53 0005
Serial number: % %
Coding: 000500
Shop #: WSC 00000 000 40960
ASAM Dataset: @V_ImmoZUDS_VDA_RM09 D03009
ROD: N/A
VCID: E8D520E0138D9A5EBC3-80BD
No ASAM data for: "@V_ImmoZUDS_VDA_RM09" (VW36)
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 G HW: 5N0 035 342 G
Component: SG EXT.PLAYER H19 0770
Revision: A1001003 Serial number: 7666620365
Coding: 020100
VCID: 2B5F1FEC4AFBF146111-807E
Address 37: Navigation
Cannot be reached
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11230
Shop #: WSC 00788
VCID: 2F670BFCEAE38D663D9-807A
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 R HW: 1T0 035 680 R
Component: RNS-MID H23 6270
Revision: AB001001 Serial number: VWZ6Z7N7364037
Coding: 00000440010000810005
Shop #: WSC 01357 011 00200
VCID: 3D7B21B4A48F6FF6BF5-8068
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V12 8195
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 6R0 907 534 HW: 1K0 907 951
Component: Batt.regelung H38 0025
Coding: 030B1A5A
VCID: F4ED449057456EBE00B-80A1
Subsystem 1 - Part No SW: 6R0 915 181 B HW: 6R0 915 181
Component: J367-BDM H07 0150
Address 69: Trailer (J345) Labels: 1K0-907-383-MY8.lbl
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Towbar module H09 0100
Revision: 3A001001 Serial number: ¿¡006789000000
Coding: 0100000100000000
VCID: 3065088063DD929E243-8065
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 N HW: 7P6 035 730 N
Component: TELEFON H15 4217
Revision: 1B001001 Serial number: 00007699999999
Coding: 0210000000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA.rod
VCID: 3D7B21B4AC8F6FF6BF5-8068
End ---------------------------------------------------------------------
May I thank you for taking a look and if you know what to do... would be awesome.
Gracias.
The case is:
Address 01: Engine
Cannot be reached
Revision: --------
Revision: 0002S 02
Coding: 58BC30
Coding: 48BC30
Coding: 820000
Coding: 310001
Coding: 003232
Coding: 540A00
Coding: 2500C2
Serial number: % %
Coding: 000500
ROD: N/A
Coding: 020100
Cannot be reached
Coding: 11230
Shop #: WSC 00788
Coding: 030B1A5A
ROD: EV_UHVNA.rod
Gracias.
Ciclo, need some help. What is the easiest way for routing a thin wire through the firewall/bulkhead? I saw the rubber grommet for the hood release cable but it is located a bit inside and may have to remove the wipers and the plastic trim to gain access. Is there another point?
Thanks in advance!
Thanks in advance!
New coding:iichel wrote: I'm working on retrofitting OEM xenon with 10 to 14 pin adapters.
The car is a 2011 Polo 1.2TDI bluemotion with start/stop. I am therefor looking for a coding that makes them work.
Gracias.
3CB02BB808210000002809F07F2B9CD9DF80673F7EA61001A00000000000
Also I recommend you read here (Crave89): http://www.uk-polos.net/view ... 95#p483778
Note to others:
The process of retrofitting xenon headlamps with 10 to 14 pin adapters for Bluemotion is not the same as for non Bluemotion.
