Restoring lost abs long code with new vcds hex v2 pro
Re: Restoring lost abs long code with new vcds hex v2 pro
What about this one?
230224E3216D00B4C42D24E784D900801700
Thank you so much for all your help again, it’s accepted that code. BUT, it’s got the tyre pressure light on the cluster and the traction control light. There aren’t any fault codes though? Could this be to do with the code at all?
You could try to hold the TPMS button after you switched on the ignition.
Did you calibrate the steering angle sensor? ESP basic settings/system function test done?
I do apologise for the slow replies. This car doesn’t seem to have TPMS on it so I’m not sure why the light is on? And yes I’ve tried to reset the steering angle sensor and it says it’s done it and the TC light just still shows up
Okay I’ve now got the TPMS light to go out but the TC light is still stuck on, it’s got 1 fault code in the ABS module, I’ve reset the steering angle sensor. Any ideas?
Go to the abs module, security access, 40168, basic settings, basic setting of ESP unit.
I’ve just got home and that’s me done for the weekend. I’ll try that first thing Monday morning. Thanks for everything
Cheers buddy, enjoy
Just realised I forgot to reply! Ever so sorry! It worked a dream and it’s all sorted. Couldn’t thank you enough, would have never got there without your help and guidance. Top man. Thanks again.
great can you tell us what exactly you did to calibrate the steering angle please?
I used the Bosch KTS machine to do it, always find it easier on that
- Drives: VW Polo 1.2 TDi Manual
Can someone help me with the long coding with abs pump please?
Will be much appreciated
I Tried to code it myself, but saying out of range, here and there im not sure what to put in. Especially where they say invert hex
2014 VW Polo 1.2 TDI
RHD
Manual gearbox
VIN no: WVWZZZ6RZEY249398
Engine Code: CFW456542
TPMS: YES
Front discs 255mm
Rear drums 200mm
VAG number: 6R0 907 379 AS
Component: ESP9.0i front H03 0003
Vehicle Identification No: WVWZZZ6RZEY249398
ModelPolo: Blue Motion
PO Date of production: 07.04.2014
Year: 2014
Sales type: 6R123N
Engine Code: CFWA
Transmission Code: MZN
Axle drive: 5S
Equipment: RY
The code shows all zeros
RHD
Manual gearbox
TPMS: YES
Front discs 255mm
Rear drums 200mm
Year: 2014
Sales type: 6R123N
Engine Code: CFWA
Axle drive: 5S
Equipment: RY
RHD
Manual gearbox
TPMS: YES
Front discs 255mm
Rear drums 200mm
Year: 2014
Sales type: 6R123N
Engine Code: CFWA
Axle drive: 5S
Equipment: RY
RHD
Manual gearbox
TPMS: YES
Front discs 255mm
Rear drums 200mm
Year: 2014
Sales type: 6R123N
Engine Code: CFWA
Axle drive: 5S
Equipment: RY
RHD
Manual gearbox
TPMS: YES
Front discs 255mm
Rear drums 200mm
Year: 2014
Sales type: 6R123N
Engine Code: CFWA
Axle drive: 5S
Equipment: RY
RHD
Manual gearbox
TPMS: YES
Front discs 255mm
Rear drums 200mm
Year: 2014
Sales type: 6R123N
Engine Code: CFWA
Axle drive: 5S
Equipment: RY
I'll need a full scan please
