Patil's T-roc 2020 1.5Tsi evo+Dsg7 RHD
Re: Patil's T-roc 2020 1.5Tsi evo+Dsg7 RHD
Please don't be apologetic, I know you've been putting great efforts to improve your health "Don't worry Master..... It takes time to get back in the swing of things"
Thank you for inputs on highline RVC. I am all set to give it a try. I will install highline RVC simultaneously along with new logo 5H0853630ADPJ. I am not after dynamic lines and other fancy views. But I guess with highline RVC, I can enable orvm puddle lights as courtesy lights while reversing, will be useful during night. For calibration I can get printed VAS 6350, I have the file. Also have few datasets, If I need I will definitely ask for your help.
New capacitive touch steering wheel installed + ACC activation in Progress
I'm not 100% sure, but I think the puddle lights (manoeuvring lights) will only work with 360 cam. But it would be nice to give it a try of course
oh, I thought It was possible with highline RVC by enabling a bit in 6C and enabling adaptation in BCM. Let's find out.
Finally ACC makes it's way in my rocc
Details coming soon
Details coming soon
Great! The improvement is substantial.
Looking forward to seeing those details, so as not to ask about the activated options (ACC + 'CCS' + Limiter).
Thank you dear Master
This ACC thing is new to me.. am learning it cautiously
I have a question, may be looks stupid, but does the brake lights turn on everytime ACC auto brakes?
Yes, the brake lights will turn on if ACC brakes, and also when car is held in place during TJA. But not when only the throttle is released, i.e. in pACC circumstances.
Dear Master you should look at the description in the link if not already seen.. damn Chinese
https://a.aliexpress.com/_mKAWTPw
Thanks for the link my dear Doctor!!!
You can't imagine the immense personal satisfaction I feel when someone uses my ideas or things I do (anyone in this wonderful world, 'without exception').
I know that others with other ideas would be bothered by these things and would even claim legal circumstances for copyright or monetary benefits, 'which I deeply respect and support', but I see it from another point of view (which you already know my dear Doctor ).
Today is a better day for me!
Log#21
Central storage compartment illumination:OEM
Connector: 1J0 973 119, Terminals JPT 1.5 ( 000979019E)
There is already factory cut for lamp in the roof portion of central console trim.
WD:
Installation:
Result:
The led is not very bright, and also black colour of trims, rubber floor mat absorb significant light. The brightness can adjusted via MIB. Very useful light, atleast something is better than nothing. There is a scope for conversion to multicolour light, when I take up multicolour ambient light project.
WD:
Installation:
Result:
This module 75 (telematics) is a pain. It's usefulness in the part of planet where I live is ZERO.
Sporadic false triggers, very annoying especially while driving. Autoscan doesn't register any event.
I've played around coding and adaptations, no use. No fix/ solution yet.
Only way to get rid of error is to switch off ignition, open and close driver's door and turn on ignition.
why not remove module 75, code it out and loop microphone? I'm sure PDC will give an error, like i have
I had thought of removing it several times, but to access it, I have to remove entire dashboard.
Can't disable it by coding alone or just unplug the connectors, fuse etc.. it's a beast... Can't get rid of it
