Ok, so you don't want people knowing you've got a 1.2 under the bonnet , or just prefer the smooth look.
To remove the rear badges, just follow these simple steps.
Yeah this is a good way to debadge. You can use a piece of cardboard as an alternative to dental floss if you want.
Do you know if removing side strips on a mk4 is done in the same way?
Only guessing here as I haven't got a mk4 but I'd say they were stuck on in the same way....so you could use the same method. Not sure if it'll reveal holes though as on the mk6. Better off asking in the mk4 forum
yeah i wanna de-badge the vw off of my polo 6n2 rear, cos its bloody chunky and ugly! can you use the same method as for de-badging numbers and letters from the rear?
-Ben-
Some more hints......
You could use boiling water if you dont happen to have a hair dryer, but this does take longer and.... I found out that if you do have like bits of the rubber/glue stuff you can use auto glym paint restorer and rub it alot, and the it comes up all shiny and good!! Hope this helps anyone....?
wow a whole year and nearly 3 months and a post gets re-surrected!
gotta be a record
2pac anyone?
yeah cheers for the help, a nice hot sponge helped me no-end, getting the sticky bits off.
-Ben-
