I'm lowering my beast by 40mm and I'm only changing the springs i have standard shocks at the moment . does anyone know if this will screw them up or will it be okay?
finally! people start to realise that you can lower on standard shocks.... I was expecting the "YOU MUST CHANGE YOUR SHOCKS" answers from people who have done that themselves.
you'll have a less than optimal ride but it's fine, get it slammed
40mm? i got 30mm and i hate it. the back is livable i suppose but the front is way to high. i reckon about 50 at the front and 30 at the back is fine for now. ig to 15" alloys to.
justsayno wrote:I'm lowering my beast by 40mm and I'm only changing the springs i have standard shocks at the moment . does anyone know if this will screw them up or will it be okay?
Ax
x
which model mk5 have you got? Eibach do a sportline kit for some models which gives a 45-50mm drop. Should give you a nice ride...
