I've had a 1999 polo for the past two years and have since covered 10k miles (60K on the clock) and have never serviced it
It did not come with the owner's manual or any other service documentation etc.. Is there an online copy of the service schedule and/or the owners manual available anywhere?
I've looked everywhere (google, pdf search sites etc.) but i couldn't find anything of use.
I'm assuming the usual air filter, oil and oil filter, spark plugs.
I would appreciate it if someone could kindly list what needs to be done and any recommended brand/type of parts to use.
Thanks!
Service schedule? What is needed for a full service?
Re: Service schedule? What is needed for a full service?
Its a 1.4 petrol BTW
so yeh with a service new oil, oil filter, air filter, spark plugs, if its not been serviced in 2 years then HT leads are a good un, might have damp in them so new ones can help. also check brakes over e.g. enough pads, sometimes bleed the brakes to be sure. once ive done that i normally take it to garage for tracking and balancing but depends on what your wanting really.
get yourself a haynes manual only 20 quid from most motor shops (Y)
