Upgrade H7 Headlights to BiXenons in Polo GT TSi
graaja
Drives: Polo GT TSi
Post by graaja »
I am from India and I have a 2015 manufactured Polo GT TSi. The car came with H7 halogen headlights. I would like to upgrade to OEM Bi Xenons with AFS. From various threads in this forum, I understand this will involve the following upgrades.
1. Upgrade the BCM from "6R0 937 087" to "7H0 937 089" or above
2. Upgrade the headlight wiring to enable BCM to control the headlights
3. Install OEM BiXenons
4. Install AFS modules and wire the AFS to BCM and headlights
I request experts to guide me with the following.
1. Part number of the BCM that I need to upgrade
2. Required wiring looms.
3. Part number of BiXenons. I found part number 044453 and 044454 Valeo BiXenons in eBay. Are these the correct ones?
Once I have the BiXenons installed, I think I should be able to follow the below thread to get the AFS installed.
viewtopic.php?f=56&t=68178
Thanks in advance for all the pointers.
Below is the picture of the fuse box.
Below is the VCDS scan of my car.
VCDS Version: Release 15.7.0 Running on Windows 7 x64
Data version: 20150820
http://www.Ross-Tech.com
Tuesday,22,November,2016,09:49:13:04550
Chassis Type: 60 (6N0)
Scan: 01 02 03 08 09 15 17 19 25 37 44 56
VIN: MEXJ15605GT032660   Mileage: 7260km-4511miles
37-Navigation -- Status: Not registered 0011
56-Radio -- Status: Not registered 0011
Address 01: Engine (J623-CBZB)       Labels: 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 KC    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 6270
   Revision: --H10---    Serial number:
   Coding: 00250056232400080000
   Shop #: WSC 01234 785 00200
   ASAM Dataset: EV_ECM12TFS02103F906070KC 004006
   ROD: EV_ECM12TFS02103F906070FJ.rod
   VCID: 6DC9DE9FED9107EAC426679-8038
Readiness: 0000 0000
Address 02: Auto Trans        Labels: 0AM-927-769.clb
   Part No SW: 0AM 300 065 N    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 6501
   Revision: 00043014    Serial number: CU501507015169
   Coding: 0000020
   Shop #: WSC 01324 785 00200
   VCID: 3A6325C3EC5F6CD2112454D-806E
Address 03: ABS Brakes (J104)       Labels: None
   Part No SW: 6R0 907 379 BN    HW: 6R0 907 379 AS
   Component: ESP9.0i front H03 0001
   Serial number: --------------
   Coding: 62DD2463422603C2461A246F4251C0800908
   ROD: N/A
   VCID: 0B0DB007F345A9DA7A12A91-805E
No ASAM data for: "EV_Brake1ESP90iBOSCH" (VW26)
   Part No SW: 6R0 907 044 Q    HW: 6R0 907 044 Q
   Component: Climatronic   H12 0615
   Revision: V0000000
   VCID: 4191522F8189330A50EE1B9-8014
Address 09: Cent. Elect. (J519)       Labels: 6R0-937-08x-09.clb
   Part No SW: 6R0 937 087 R    HW: 6R0 937 087
   Component: BCM PQ25 H+4  H34 0424
   Revision: BF034001    Serial number: 0681 139150831
   Coding: 3AB02BBF08A10000003800007C2A149000C0414F608C0000200000000000
   Shop #: WSC 12469 483 00190
   VCID: 4C8F731BB6CBEE62B398925-8018
   Subsystem 1 - Part No SW: 6R0 959 802 CC    HW: 6R0 959 802 CC  Labels: 6R0-959-802.CLB
   Component: -------------  007 5551
   Coding: 050000
   Subsystem 2 - Part No SW: 6R0 959 801 BT    HW: 6R0 959 801 BT  Labels: 6R0-959-801.CLB
   Coding: 050000
   Subsystem 3 - Part No SW: 6C0 959 442     HW: 6C0 959 442
   Component: E221__MFL-TAT  H04 0019
   Coding: 240000
   Subsystem 4 - Part No SW: 6R0 959 811 L    HW: 6R0 959 811 L
   Component: -------------  006 5550
   Coding: 020000
   Subsystem 5 - Part No SW: 6R0 959 812 L    HW: 6R0 959 812 L
   Coding: 020000
   Revision: --------    Serial number: 003GW010KR6J
   Coding: 003036
   ROD: N/A
   VCID: 49814A0FB9B9FBCA88BEF39-801C
No ASAM data for: "EV_AirbaVW10BPAVW250" (VW26)
   Part No SW: 6RF 920 861     HW: 6RF 920 861
   Component: KOMBI         H01 0214
   Coding: 140800
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
   ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
   VCID: 08078F0BE233C2C257308E5-805C
   Coding: 140800
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 6R0 937 087
   Component: GW-K-CAN TP20 H34 0424
   Revision: BF034001
   Coding: 002300
   VCID: 70F7C7EBFAA3EA82EF00065-8024
2 Faults Found:
            000 -  -
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 7265 km
                    Time Indication: 0
                    Date: 2015.02.22
                    Time: 09:41:11
00470 - Company Comfort Databus in Single Wire
            012 - Electrical Fault in Circuit
                    Fault Status: 01101100
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 138
                    Mileage: 7265 km
                    Time Indication: 0
                    Date: 2015.02.22
                    Time: 09:41:11
   Component: IMMO          H01 0214
   Serial number:
   Shop #: WSC 00000 000 00000
   ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
   VCID: 6AC3D583DC7F10D2A14444D-803E
Address 37: Navigation
Cannot be reached
Address 44: Steering Assist (J500)       Labels: 1Sx-909-144-44.clb
   Part No SW: 1S2 909 144 P    HW: 1S2 909 144 P
   Component: EPS_ECU       H61 1702
   Coding: 0001000000000000
   ROD: EV_SteerAssisNSK_SE12.rod
   VCID: 4191522F8189338A50EE1B9-8014
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 02:34)-------------------------
Re: Upgrade H7 Headlights to BiXenons in Polo GT TSi
With 7H0 BCM could have incompatibilities with other units for YOUR 6R (2016 MY)
According to ETKA and VCDS Autoscan the BCM would be: 7E0937090B 0CS (8IT), also would work for 8IG due our experience.
8IT = Led Headlights
8IG = Bixenon Headlights
IMHO it's better install LED Headlights (8IT) for your 6R, the cost would be similar. With 8IT YOU would avoid having to change the fog lamps wiring installation.
graaja
Drives: Polo GT TSi
Post by graaja »
Thanks a lot for the quick reply.
I had first compared LED and Bi-Xenon headlights and decided to go for Bi-Xenons due to features like automatic leveling and cornering functions and also the Bi-Xenons would provide better lighting under rainy conditions due to the 4300K warm lighting. I thought LED light would be on the whiter side and will not have good lighting under rainy conditions.
I have a few questions on your BCM suggestion.
1. What is 8IT and 8IG. Are they variations of the BCM that support BiXenon lights vs. LED lights?
2. Do the LED headlights come with automatic level control, and cornering functions? I could not find much information on LED headlights.
3. I saw in some article that the BCM also has to support the radio frequency used by the keyfob. In my keyfob, the frequency is mentioned as 434MHz. Will the 7E0 937 090 B support this frequency?
4. In case I want to go with Bi-Xenons instead of LEDs, will this BCM completely support BiXenon as well? Or would you recommend a different BCM which is specific to Bi-Xenon control?
5. Can you point me to a web store where I can order this BCM? I searched eBay, but could not find the 7E0 937 090 B.
Please pardon me for the long list of questions.
ETKA, PR-codes, etc... viewtopic.php?f=10&t=42713#p466570
I am sure that when you know how to handle ETKA with the PR-codes you do not need to ask so many questions.
Web store? I don't know, but it is impossible that you can not find the parts you need online. :lol:
I am not able to see the image of your fuse box in your first post. :mrgreen:
graaja
Drives: Polo GT TSi
Post by graaja »
ciclo wrote:ETKA, PR-codes, etc... viewtopic.php?f=10&t=42713#p466570
Thanks for the links to ETKA. I will search online for the BCM.
I have edited my first post with the link to the picture of the fusebox. I hope you are able to access the picture.
Sincere apologies once again for all the newbie questions :oops:
You do not have to apologize, they are not newbie questions.
The same images you can see here are necessary to get help in the best way possible. :wink:
I have not counted the immense amount of different 6R that are manufactured in this world, but I can assure you that it is difficult to find two equals.
You can show us pictures of your 6R if you want... More info = better help. :lol:
graaja
Drives: Polo GT TSi
Post by graaja »
Here are the pictures of the fuse box and the headlight switch connector.
Can you tell me where I can find the relays and the wire dimmer connector, so that I can get these pictures as well?
Yes, the relay carrier image is required, and also from dimmer connector.
Recently and with the same purpose I have studied a VW Polo whose fuse box is like yours. :wink:
This is not for you, but if you read here...
https://drive.google.com/file/d/0B2nv91 ... ZQN1U/view
graaja
Drives: Polo GT TSi
Post by graaja »
ciclo wrote:Yes, the relay carrier image is required, and also from dimmer connector.
Here are the images of the dimmer connector. In my car, actually there is no dimmer, only the manual headlight range adjuster.
However, I have not been successful in opening the trim below the steering column to expose the relay carrier :?
Found two screws at the bottom of the trim which I removed. Tried to pull the trim, but the trim was stuck too strong. I forced the trim open and I think I broke a few locks, but still could not get the trim completely out. Not sure if there are any other screws that I missed! Could you please guide me to some instructions on how to open the trim below the steering column?
It is impossible to build an airport if you do not know how to build a camping tent. :lol:
Even though you already have the right tools.
Please click on the following links.
viewtopic.php?f=56&t=69121#p515546
http://workshop-manuals.com/volkswagen/
Imagesearching in the left dialog...
http://workshop-manuals.com/volkswagen/ ... end_trims/
graaja
Drives: Polo GT TSi
Post by graaja »
Managed to take the picture of the relay carrier :D Took the picture through the headlight switch opening.
Before this, I was actually trying to open the trim pointed by the read arrow, and that is what proved to be too difficult. I think I unnecessarily broke some locks in this trim :oops:
Do not worry, we fall to rise again. The dashboard is only one piece and can not be disassembled by parts.
Try to repair those broken locks with accurate to avoid unnecessary noises. There are very effective glues for plastics, I use the VW glue for glass (bonded forever). Here you can see the reference D 180 KD2 A1 if you want to use it.
It's the best image I've ever seen from a 6R RHD Relay Carrier. :wink:
I'll study the electrical installation, be patient please. Meanwhile you can show us an image of the radio area and current headlights.
Having to request pictures is the part of these processes I hate most. I have already commented that there are many differences between Polos 6R that are sold in different markets, it also depends on the years of manufacture and specs of each one.
I do not have a search engine for parts with the VIN.
graaja
Drives: Polo GT TSi
Post by graaja »
ciclo wrote:Do not worry, we fall to rise again. The dashboard is only one piece and can not be disassembled by parts.
Sure I will check out the glue and get the loose trim tightened again. And thank you for your kind words about the picture :)
Here are the pictures of the radio area and the headlight.
This is the original radio that my car had (I have now changed this to DS611 from Audiosources. This picture was taken during the HU swap)
There are two ISO connectors for the radio connection. These have the CAN signals as well.
The OE H7 halogen headlights
The headlight switch. There is a manual headlight range control. But no dashboard backlight dimmer control.
The 10 pin connector on the headlight
The 10 pin connector on the wiring
Please let me know if you need any other pictures from the car. I will be very glad to post them.
Edit: There was an image added to the post which I had not added. Removing the image
They are enough images, many thanks. Nice 6R GT. 8)
Maybe more information about your new HU DS611. PDF installation guide, or the price would be interesting. TEST
What about CAR menu?
