Coding parking sensors
Andrea 6r
Drives: 6r
Post by Andrea 6r »
hello everyone,
I wanted to know why error appears when I try to activate, with vag 10.6.4, parking sensors
thanks
Re: Coding parking sensors
well it's pretty self-explanatory, right? you need to enter a code in the button 'security access' at the right bottom. ;)
it's 71679
Andrea 6r
Drives: 6r
Post by Andrea 6r »
I tried but it seems to enter is not saved and buy -31 error
Inviato dal mio iPod touch utilizzando Tapatalk
location where to give in the security access -->
Andrea 6r
Drives: 6r
Post by Andrea 6r »
I make a screen just try
but I have already tried to add the access code
Andrea 6r
Drives: 6r
Post by Andrea 6r »
I tried to enter the security access that is accepted
but when I try to change something in the coding is still found "error 33 security access"
if I try to insert a random number, in coding, you get this error
but I think it's normal
before I was referring to this
Andrea 6r wrote:I tried but it seems to enter is not saved and buy -31 error
look precisely.
in the first post, you have an error 33
error 33: security access required
in your last post, you have an error 31
error 31: request out of range (meaning: your coding does not make any sense)
which is logical if you put in random numbers.
there is a difference between error 31 and 33 ;)
Andrea 6r
Drives: 6r
Post by Andrea 6r »
perfect :D
on coding, then error 33, there is more to try? :roll:
enter correct security code, and then give in a sensible coding, then it should be ok.
Andrea 6r
Drives: 6r
Post by Andrea 6r »
I tried to insert the codes: 100101 and 100101
but AFTER you have entered it (logically one at a time) appears safe access
although I try encoding "Manual" from the coding that appears safe access
it seems that is not "saved" this security access is required
It happens many times that the China pdc module does not allow the code to be changed, unfortunately
Andrea 6r
Drives: 6r
Post by Andrea 6r »
Grazie Jay-Jay
It was only hold vag
