Polo gti 6n2 won’t start!
- Drives: 6n2 gti 1.6 16v 2001
Hey guys! My gti won’t start, it’s trying to. It ticks over then just dies. I think it’s fuel related but not to sure.. anyone else had a similar problem?
- Drives: Landrover Freelander
Re: Polo gti 6n2 won’t start!
When my ‘fro’ is misbehaving I tend to use a fro pick and some good spray
Bloody autocorrect [emoji23][emoji23]
- Drives: 6N2 GTI, Golf GTD + R32, T5.1 BiTDI DSG
When was the fuel filter last changed? They can cause this symptom.
I’m not to sure, I’ve got a new one to fit but I can’t get my car up to get under to fit it [emoji23]
I’d change that first. There is a ‘how to’ on here somewhere. It tells you which fuse to pull to kill off the fuel pump, start car to drain pressure away until it cuts out then change the filter, refit fuse and crank until it starts again.
Hope that fixes it....
- Drives: 6n2 polo GTi
What does it do exactly? Does it actually start?
It does for literally a second maybe 2 then cuts out, try starting it again & it doesn’t. But if you leave it like 10 mins or so it’ll do the same thing
Immobiliser, mine did exactly the same.
I’ll check that to! Thank youBazzad88 wrote:Immobiliser, mine did exactly the same.
Replaced fuel filter.. wasn’t that [emoji23] still doing same s**t
This 100% sounds the what mine used to do and it was the immobiliser. Mine would cut out while driving and not start for anywhere between 5 and 30 minutes. It eventually got to the point where the car would start for 1 second and completely die and that's all it would do. I changed the ecu, immobiliser box and key chip and it started fine.
Yea it is, my mate finally come round with his scanner & it’s the immobiliserBazzad88 wrote:This 100% sounds the what mine used to do and it was the immobiliser. Mine would cut out while driving and not start for anywhere between 5 and 30 minutes. It eventually got to the point where the car would start for 1 second and completely die and that's all it would do. I changed the ecu, immobiliser box and key chip and it started fine.
Thought as much, what I did was get an ecu, immobiliser box and key chip from another polo. It all has to come from the same polo. The part number will be on the ecu, try to get the same code. Glad you found out the problem.
I’ve got an auto electrician coming out to disconnect it [emoji23]Bazzad88 wrote:Thought as much, what I did was get an ecu, immobiliser box and key chip from another polo. It all has to come from the same polo. The part number will be on the ecu, try to get the same code. Glad you found out the problem.
