Hi Everyone
First post here, so excuse any errors. Both my brake lights are out on my Polo and I want to change the fuse...but can’t work out which it the brake light fuse on the fuse card. Any ideas? I have images of the fuse card but can’t upload them. I think it’s number 15 which is a round circle with a bulb in the middle of it.
Brake Light Fuse 2001 Polo Y Reg
- Drives: 2001
- 937carrera
- Drives: 2000 Polo GTi
Re: Brake Light Fuse 2001 Polo Y Reg
Welcome
I believe you are correct....... that was harder to find on the wiring diagram than I expected
- Drives: 2001
Ah cheers 937carrera. Having so much trouble with my brake lights. I have swapped out fuse and bulbs but they are still not working. Last try is the brake switch which I didn’t really want to get into.
- 937carrera
You really need a multimeter to test, you'll get a basic one for a tenner or so.
The current flow is Fuse 13 > brake light switch (terminals 1 & 4) > 10 pin connector > brake lights.
Are you sure the earth from the light cluster is good ?
- Drives: 2001
Solved the problem. I pulled the plunger out of the brake switch and the brake lights started working. So it seems that I will need to change the brake switch. It works for awhile and then the plunger (or whatever the button thing is called) gets stuck again. But cheers for your help. Much appreciated.
