Hello!
I drive a 2004 9N Polo ( 1.4 petrol ) and I had an issue where the ABS light would come on and the Handbrake light would be flashing and 3 alarm beeps would go off.
After doing some research, I checked the fuses on top of my battery, and indeed, the 40 amp ABS fuse was blown. At that point I was sure that was the issue, and purchased the 40 amp fuse that was needed.
I replaced it, but the warning lights and the beeping didn't stop.
Any ideas what to check next? Could it be a connection issue? I didn't sand the connecting bolts and surfaces, they looked clean to me and were not corroded.
ABS light on + Handbrake light still flashing after blown fuse replacement
- Maarten
- Drives: AW R-line Facelift MY2022 Vibrant Violet
Re: ABS light on + Handbrake light still flashing after blown fuse replacement
When was your last brake fluid change?
Are your brakepads still good?
Are all the big fuses good on top of your battery?
Did you run a diagnostic scan?
Module 3 ABS
Module 3 ABS
- Drives: Polo 9N 2004 1.4 16V petrol
Update:
I sanded the connections and took her for a spin, the warning lights finally disappeared.
- Maarten
Thanks for the feedback.
Glad is it solved!
Glad is it solved!
