LED reversing light
d-ash
Drives: 6C 2016 R-Line 1.2 90PS - Blue Silk
LED reversing light
Post by d-ash »
I've ordered LED replacement for the pitiful reversing light. I've been finding it a real struggle to see where I'm going in the dark, when away from street lamps, using the standard bulb.
Here's what I've ordered...
http://www.hids-direct.co.uk/382-p21w-w ... anbus-led/
They should be very bright (60W equivalent), and shouldn't cause any canbus errors.
The only catch is having to order a pair. I might have a spare to sell :wink:
Dave
Rik762
Drives: 2017 Polo GTI DSG
Re: LED reversing light
Post by Rik762 »
Yes.....I used one of those in my Polo. Vastly better but the design of the rear-light itself limits the improvement.
d-ash
Post by d-ash »
Cheers Rik. That's one of the reasons I chose the 60W equivalent with a lens to project as much light as possible :wink:
Any tips to removing the light fitting? Does it just push out once the white plastic screw has been removed?
Dave
Rik762
Post by Rik762 »
Yes it pushes out. Just ease it gently and don't drop the big white screw. The tricky bit is releasing the electrical plug. I can't remember which bit to squeeze to get it out.
d-ash
Post by d-ash »
Thanks Rik
I think you squeeze the tabs on each end of the connector block. I'll soon find out; the LEDs are in the post !!
Dave
Dink
Drives: 2015 GTI
Post by Dink »
what i'd like to see is the real information for those lamps
as they look like the 5 quid jobbies off ebay
I think that I should maintain an interest in these LED units as well, wife tells me the reversing light is - well not good!
Rik762
Post by Rik762 »
She is very polite.
Dink
Drives: 2015 GTI
Post by Dink »
Rik762 wrote:She is very polite.
:lol: :lol: :lol: :lol: :lol:
CNK
Drives: 6R
Post by CNK »
Hey, I use BA15s (1156) 10x 5W Epistar LED + LENS 50W 4500k and it works like a charm ;)
Pictures :arrow: https://www.drive2.com/l/457795686071602666/
Perhaps these films will be helpful for people who want to replace a light bulb in the tail light:
https://www.youtube.com/watch?v=8x3luXziM_Y
https://www.youtube.com/watch?v=v-xLhlzGobQ
https://www.youtube.com/watch?v=OafL8gDKk4Q
d-ash
Post by d-ash »
Looks same design as what I've ordered. I'm getting the 60W equivalent version. So should be brighter. :wink:
Thanks for those video links
CNK
Drives: 6R
Post by CNK »
d-ash wrote:Looks same design as what I've ordered. I'm getting the 60W equivalent version. So should be brighter. :wink:
Yes, they should be similar, I bought this bulb three years ago, I haven't found brighter then :D
It fits to LED license plate lights.
d-ash
Post by d-ash »
Installed the LED today. You need small hands !! Had to first undo a large nylon screw to release the tail-light assembly (access through small hatch in the boot lining), then slide a small red shield back on the connector block which allows the, then accessible, connector block release tab to be squeezed. The assembly holding the bulbs is held by 4 clips.
The LED works without any error messages, is white and bright. Can't test it properly until dark tonight.
Update: although brighter, and doing a better job of illuminating objects at tail-light level, unfortunately the lighting at kerb level is no different. I guess this is down to the design of the tail-light housing which doesn't include a reflector. Oh well, it looks good; nice white bright light (in keeping with the LEDs above the number plate !!
