Hi
Our 1996 Diesel Polo is making any insults about diesels being tractors true! Its fine when its running along but when its idleing at the lights etc its annoyingly noisey. The noise sounds as if the exhaust is banging against something but a mechanic checked it out and said it was fine. Give it a little gas to get it over 1500Rpm and its fine.
Is it normal or is it likely to be broke?
Ta
Joe
Are 1.9 Diesels normally noisey?
joebickley
stuart_hatch
Funny you should say that, i have a 1.9 and i was thinking just how quiet it was. So maybe something is wrong, or it could come with age depending on mileage etc. Diesels tend to get noisy as they get older. A regular service helps prevent this.
Have you checked that you still have a engine tray under the engine, this shuts out a lot of the noise.
James14100
