03 Polo
Discuss In Car Entertainment
robbiehall
03 Polo
Post by robbiehall »
Has anyone replaced the factory speakers with coaxials or components? There doesn't seem to be alot of room in the door.
Rob
carmadaaron
Post by carmadaaron »
is this on a 3dr or 5dr?
robbiehall
Sorry, a 3 door :oops:
Rob
M7
Post by M7 »
i have...
although i got bassmechanix to fit mine, a company in newcastle. they told me their is nowhere to fit speakers in the rears, not even anywhere to build a wooden mount.
in the front i have 6 1/2" speakers and they are in wooden door builds, that they constructed.
robbiehall
Cheers for that.
I am hoping that my local firm can fit some Image Dynamics in the doors, but do wonder if I might be better off forgetting that and putting some 6x9's in a stealth rear shelf instead.
Anybody got some thoughts on that?
Can you buy the plastic door trim retaining plugs anywhere?
Rob
SiDaBa
Sponsor
Post by SiDaBa »
2fast4u wrote:i have...
Bit of a fib.
I would have changed the rear one's in my last polo if i'd kept it.
carmadaaron
do you guys with 3dr cars have 'holes' in the panel?
robbiehall
Well, AFAIR the card has a cutout for a grill which sits up tight against a plastic ring with a square outer (with a floppy sealing ring) that goes round the speaker (which is pop-riveted to the door) and fits between the two.
So there sort of is a hole, but it is covered by a square (colour coded) grill.
I haven't looked behind the rear panel, but am not hopeful there is much space there.
Rob
carmadaaron
not sure on the 3dr, but on my 5dr, i bought speaker adapters from autoleads, but they dont fit ! :!: :x
SiDaBa
Sponsor
Post by SiDaBa »
I ment to put a link in my last post :roll:
http://www.tigerstyle.co.uk/poloforum/v ... r+speakers
There aren't any holes for speakers unless you get the plastic frames for the speakers like i did in my last polo.
Aaron why don't you just make your own adaptors out of MDF?
M7
Post by M7 »
i was told off the company who fitted mine that rear speakers would not go into the rears on a 3dr and vw couldnt provide any mountings, and they couldnt make any either.
now i realise they just couldnt be arsed!
carmadaaron
SiDaBa wrote:I ment to put a link in my last post :roll:
SiDaBa
Sponsor
Post by SiDaBa »
2fast4u wrote:i was told off the company who fitted mine that rear speakers would not go into the rears on a 3dr and vw couldnt provide any mountings, and they couldnt make any either.
that sound just about right from most VW's dealers. Have to admit it took a lot of error by VW to find the right parts think i must have been back and fourth about 6/7 times over a period of 3 months (just how long it took for parts to come in and discover they were wrong).
So that's what the inside of rear doors look like, will be a while before i replace my rear speakers let a lone front ones. :roll:
robbiehall
How did you guys find re-using the door card retaining clips?
And what does anyone think of using a Stealth Shelf/sub-box as opposed to replacing the front speakers? - seems to be less hassle???
Rob
SiDaBa
Sponsor
Post by SiDaBa »
robbiehall wrote:How did you guys find re-using the door card retaining clips?
Rob
Best to have extra clips, found that most of mine either had broke from the person who did it or i broke some when putting them back on.
I also had a stealth shelf. Dunno what spec your car is but I found in my 1.2 the weight of a stealth shelf & sub obviously weighed the car down and slowed it down. Not only that if i take corners (roundabouts) at a fast speed with all that installed the back would start to slide out.
still these are choices you must make :)
