QUICK AMP QUESTION
AKs_SlickPolo
QUICK AMP QUESTION
Ive got a quick yes or no amp wiring answer. the red wire for the power doesnt have a ring connector. i went to halfords to get one and he said that u HAVE to use a gold plated ring connector that mounts onto the battery. is this true or will a normal silver one do, cos i cant find any gold ones?
ModifiedMadness
- Sponsor
AKs_SlickPolo
Yeah originally the wire came with a gold plated one, (the autoleads amp wiring kit) but i had to cut a bit of the wire off in order to shorten the distance between the battery terminal connection and the fuse. but i cant uncrimp and recrimp the one of the cut off wire. tried 2 halfrauds they said they do sell em in a pack of 4 or something in a autoleads box but they aint had them 4 a long time. ideally i doubt using a silver one will make a difference, but i think i better wait until i get a definete answer 4rm someone. thanks though dude.
carmadaaron
try maplins. they have them for sure... £3 i think it was.AKs_SlickPolo wrote:Yeah originally the wire came with a gold plated one, (the autoleads amp wiring kit) but i had to cut a bit of the wire off in order to shorten the distance between the battery terminal connection and the fuse. but i cant uncrimp and recrimp the one of the cut off wire. tried 2 halfrauds they said they do sell em in a pack of 4 or something in a autoleads box but they aint had them 4 a long time. ideally i doubt using a silver one will make a difference, but i think i better wait until i get a definete answer 4rm someone. thanks though dude.
AKs_SlickPolo
tried maplins mate. they dont seem to have any...eventually just got some from b&q there thin but i doubt it matters and its silver. under 50p for a generous box of em. its only a 300w amp anyways, jus so i can get the max 4rm my 6x9s, so it aint nothing special. im sure itll work just as fine for the time being. cheers for your advice guys.
