Cambelt change
][=][anson
Cambelt change
looking through the history of my car there doesn't seem to be any record of a cambelt change and this is slightly worrying me. the cart has just done 74k and i am worried if it hasn't been changed that my car may soon die
is there any way i can tell if it has been changed?? if not i guess it would be advisable to get it done, yes? if so how much am i looking at to have it done???
][=][anson
- bstardchild
- Moderator
- bstardchild
- Moderator
][=][anson
- bstardchild
- Moderator
Well you need to get enough of the timing belt cover off to enable you too look at the belt - small section and then turn the engine over by hand to look at the whole of the belt bit by bit.....][=][anson wrote:is it easy enough to check?? if so how can i??
What are you looking for? Basically......
- Smooth clean edge both sides of the belt so you know it hasn't been rubbing
- All teeth present and correct
- No cracks in the rubber between the teeth
- No cracks or frays on the outside of the belt
- Belt tension correct (twist the belt in a free section should twist 90 deg any more and either tensioner is fubar or the belt is overstretched and the tensioner can't adjust anymore
BUT and it's a big BUT
- None of the above even if all perfect will save you from the belt failing
- they have a service life and once past their replacement mileage of age it is a really big risk to continue with the same belt
IF it snaps you can say goodbye to all the valves and probably the pistons too so you then will need to find a 2nd hand engine to replace it with.
Much better just to replace it and have 3 years or 60,000 miles of worry free motoring.
][=][anson
- bstardchild
- Moderator
Hmmm depends on their labour rate - it's about 2 hrs to do - the really important thing is the tensioners - I don't know if this applies to the 16V MKIV but on a lot of cars they now replace the tensioners as well as the belt as it's often teh tensioner that breaks up and leads to the belt failing - someone with a 16V must be able to advise you][=][anson wrote:thats what i was thinking really.bstardchild wrote:Much better just to replace it and have 3 years or 60,000 miles of worry free motoring.
i've phoned VW this morning and been quoted £295 inc VAT & Labour to have the belt changed. Does this seem "reasonable"??
][=][anson
Ajit_mk2_16v
][=][anson
- bstardchild
- Moderator
Labour rate at a reputable independant compared to a VW garage makes a big differenceAjit_mk2_16v wrote:rough guide
belt £15
tensior £25
my garage in london (independent) charged 2 hours labour at £100
take the VAT off = £250
Say VW parts are a tad dearer £25 and £35 for belt and tensioner respectively
leaves £190 labour or £95 per hour - sounds bout right for a dealership - damned if I'd pay it tho!!!
][=][anson
