When i say attempts, i mean that the ignition is started, the starter motor turns on and the engine turns over, at normal speed - but doesn't fire.
When it does fire, the engine runs perfectly. This leads me to beleive that spark plugs/HT leads and the starter motor work fine. The Battery is fine, unlikle to be the fuel system as it eventually works.
I was thinking that maybe there was a problem in the ignition system, mybe a faulty sensor that doesnt let the car start?
Any help will be greatly appreciated!!! If we cant sort it out and the garage can't either, its bye bye polo
