Faulty Ignition Switch
inder
Post by inder »
Having suffered from this for some time now: http://www.tigerstyle.co.uk/poloforum/v ... hp?t=12082
I searched the forum and other places, found a common problem of 'faulty ignition switch'... now could this be the reason for this noise I get upon starting the car, happens now and then, but seems more frequent now :(
Sound clip captured: http://www.zen66433.zen.co.uk/video/vrooom.wav
Ignition switch is a cheap part... but have to remove steering wheel and faff about fitting to fit a new one, long and fiddly job according to the haynes manual (even drilling out a bolt so the old switch slides out of its housing!) beyond me I think :?
Any ideas? :x
polo2k
Post by polo2k »
that noise sounds like the bendix on the started retracting, pull the starter and give it a clean in my idea
inder
Post by inder »
thanks for the info, searched the forum and someone had a similar issue... could be this issue for me too
http://www.tigerstyle.co.uk/poloforum/v ... ht=starter
Finally, the awful 'whiiiizzzzzzzz' noise when I start the thing no longer occurs! I ended up having to get a new starter motor for the thing.
how much is a new starter m8? expensive :( its a 1.4 SE 16v 75bhp AUA Type, Year 2000
also all the gaskets/o-rings that need replacing after removing the inlet manifold, as i understand, the starter motor is a b***h to get to and its best to remove the inlet manifold for easier access?????
or should i just entrust this job to the dealer :(
thanks for prices / any more info
badboypolo
Post by badboypolo »
I have just started to get this noise too!! I just got mine lowered and I told the guy about it and thinks it might be the bendix too.im going to try cleaning mine.
polo2k
Post by polo2k »
you should be able to get away with cleaning it really but if you want prices then just give us a shout in the vagparts forum
and it shoud be fairly straight foreward really just a bit fiddley at times
inder
Post by inder »
hopefully that will be the case m8
ill work out what seals I need and post in vagparts section, as I understand, removing the Inlet Manifold first gives much better access to the Starter Motor... allowing me to remove it from the car and try to clean it
cheers,
inder
Post by inder »
polo2k, what 'page' is the inlet manifold on? so I can work out what seals etc.. and how it comes apart? e.g. page XXX-XX thanks m8
badboypolo
inder did you sort the problem you had with that noise? what was it?
inder
Post by inder »
badboypolo wrote:inder did you sort the problem you had with that noise? what was it?
Yep - all sorted now... it was a worn bush on the starter motor, bush can be replaced, but I decided to replace the whole starter motor and bush, in case the internals had been damaged also
Sounds all purdy now heh :D
badboypolo
~I got the same problem, much did it skin you?
inder
Post by inder »
well the replacment starter motor was about £80 on exchange from vw (they take your old one as a swap for discounted price) and I fitted it myself with a bit of help, bit of a fiddly task, but got done. Jacked the front up
you would need to buy a bush too. I guess you could just replace the bush and it will get rid of the noise :)
JWC
Post by JWC »
yeah but you did the right thing really. Its not worth faffing with the bush, only to find that after all the blood and knuckles that is still makes a noise.
inder
Post by inder »
Indeed, was best idea to replace it all at once - was not fun with a hot flywheel though :lol:
JWC
Post by JWC »
You should have switched the engine off first! (I know it doesn't say that in the haynes!)
:shock:
:lol:
inder
Post by inder »
lol, engine was off - but had just driven it to a mechanic friend's place, in case I needed help with anything (plus for the tools, jacks, stands etc..) and just had to get on with it while the engine was still hot/warm - it cooled down eventually though heh :D :lol:
