some guidance
niks
some guidance
Post by niks »
hey guys got a mk5 polo and a k&N induction kit ..... problem is that i think that the induction kit is soaking up the enigne heat!!! SO was gonna think about making a heat shield ...hAS ANYONE DONE THIS BEFORE and what sort of material should i use and what sort of thickness???
Also by removing the existing airbox im finding the engine more noiser does any one know what sort of sound deading material exists and where to get one from...thought i saw it on the mk5 16v polos
cheers for the info hope the above info sounds clear.
inder
Post by inder »
Does you bonnet have sound deadening material attached to the underside of it? If not, this is something you could get as a VW part and fit to help with the noise
niks
Post by niks »
thats the stuff im after anyone knows how much it costs???
cheers
inder
Post by inder »
Make a post in the VAG Parts section of the forum - they will quote you a price for it :)
