Urgent Help With Coilovers
Discuss Suspension, Brakes, Wheels and Tyres
stuart_hatch
Post by stuart_hatch »
Ok, i have my AVO coilovers fittet, but when i take the car off the stands it drops a good 2-3 inchs, i belive im missing top mounts or possibly spacers.
Anyone got any ideas?
Even instructions would help!
warrmr
Post by warrmr »
rubber brushes.
does the post stick out of the topmounts like that when you drop it down. if so then the rubber brushes are missing. what you want is your old suspention struts and compress the springs and undo the bolt on the top and slide the rubber brush off the top of the post. then wind your coilies to the lowest they go then slot the brush on and put the bolt on remount them on the car then ajust to perfect height. then the post will only stick through about 10mm after the bolts are on the top mounts.
stuart_hatch
Feck, you took your time replying. Theyve been sorted for two months now ;)
carmadaaron
Post by carmadaaron »
hes a new member, just registered yesterday:)
welcome to the forum btw! 8)
warrmr
Post by warrmr »
oops didnt see the post date. i jus assumed as it was on the first page it was a new post. oh well. ill learn
