Headlight Warning Beeper
][=][anson
Post by ][=][anson »
dont know if there is supposed to be one but when you leave your lights on and open the door with most cars it gives you a beep so you know to switch your lights off if you have forgot! mine on the other hand doesn't!! is there supposed to be one in the mkIV? if not how can i put one in as i have found myself leaving my lights on quite a few times now so would benefit a little beep to remind me!!!
Thank You!!
Phil6N
Post by Phil6N »
Mine has and iv got a 1.4 8v CL model, I dont know whether it varies across the models or something?Either that or maybe yours stoped working before you purchased the car?!
Soz i can not help more!
david burton
Post by david burton »
yeah, I think it should have one - but then again it could be model specific. every polo 6n I've been in had one.
anyone got a low-spec 6n here?
hmmm. I could have a gander in the haynes later on.
][=][anson
thought it should have one! mines a 16v so shouldn't be a spec issue really. they dont do a haynes for the 16v so never bought one! any help would be greatly apreciated *can't spell* :oops:
R1CH
Post by R1CH »
mine had one but stopped working when unicar fitted my alarm,just learned to live without it,innoying though.
][=][anson
its doing my head in!!! big time, i usually have my side lights on at all times, mainly due to knowing people who have had other drivers pull out on them and said they didn't see them comming! so way i see it is the more i can make myself visible the better!! just annoying when i leave them on and get in the house then realise i can see them still on :twisted:
][=][anson
just done it again, had the girlfriends next door neighbour knocking at the door!!! grrrrrr someone must know???? please?!?!?!??!?
BLACK6N_POLO
Post by BLACK6N_POLO »
I have a 1.0L 6n (basic) and mine has the beep! i think all models should have it!
][=][anson
just need to find out where the beeper is then i can sort it / replace it
warrmr
Post by warrmr »
][=][anson wrote:just need to find out where the beeper is then i can sort it / replace it
i belive its in the headlight relay. but i may be wrong. but the haynes manuel doesnt tell you what realy number it is unless im being a fool and cant see it. oh well. mine did the same.
was working when i got the car then went to the bodyshop to be repaired from my crash and then wasnt workin.
david burton
LOL
my bird's beeper ( :shock: ) stopped working tonight too!
david burton
i had a look in the haynes
up to 1998, the buzzer is located somewhere in the fuse / relay box behind the driver's glove compartment. it's called component "c" in the haynes!
I guess if you get a replacement, you should be able to see where it should go.
after 1998, I couldn't find it - I think it's an integral part of the dash / wired up to somewhere else. I think the noise if different - which leads me to believe it might be a dash speaker or something?
mysteryboy
Post by mysteryboy »
my one screams... really annoying,,, without it id leave the lights on 99% of the time...
Visit a few garages and get some free advice :wink:
warrmr
Post by warrmr »
david burton wrote:i had a look in the haynes
what i said its integrated into the relay. and they die after a while.
david burton
I think the headlight relay is item "d" in the fuse box in the haynes manual, whereas the buzzer is item "c" so it could be it's own separate part - but I may be wrong. Are you sure it's just a case of replacing the headlight relay then - have you fixed this before?
I can't see the identification of any of the relay numbers in the haynes - which is a shame.
edit:
I've rung up VW, and pre-1998 swapover it's its own relay in the fuse/relay box. 12 pounds plus VAT. I asked whether it was part of the headlight relay and the guy said he didn't know - it's marked 9/36 or something!
after 1998 wiring-swapover he confirmed it was part of the instrument cluster.
so - you have to figure out which model you have! Easiest way to check is to look at your battery - is there a black box over the terminal with fuses inside? If so - then you're post swapover and I have no idea how to fix it!
