I know its been asked before (i did a search) but does anybody have a wiring diagram for a 6N?
Failing that, does anybody know how to remove the fuse/relay box inside the cubby under the steering wheel? I can see a grey clip that releases on the left and there seems to be one on the right but its out of sight and won't budge. Does it then lift out?
Finally if nobody knows that, where is the best place to get a permanent 12v live inside the car?
Many thanks
Stuart
wiring diagram + fusebox + 12v live
david burton
Christian6N
So tell me wwhich year wasyour mk4 manufactured exactly and then tell me what exactly you want to do....just need 12V???
How to release the complete fusebox i have once written here
http://www.vwpolo6n.de/de/tipsundtricks ... alteze.htm
....but it is in german language but with a few pics.....perhapss this helps you...but it won´t help you finding 12V......hmmm.....tell me what you want to do with that 12V....
Christian
Christian
I'm fitting a remote central locking kit. Obviously this needs a permanent 12v live (rather than ignition switched).
I'd thought about using either the radio or fag lighter for the feed but would prefer something more substantial. I just wondered if there is a way of tapping into the permanent live in the fusebox.
I'd thought of taking it straight from the battery, where is the best place to bring it in through the bulkhead?
Its a 96 1.4CL if that helps
Many thanks in anticipation.
