Gear probs!!!
Gear probs!!!
probs geting the car into gear 1st 3rd 4th pain in the arse at the lights and haven to ram it into first it just dosent want to go into these gears! an it dosent sound to good when u have to ram it in to gear
it comes and gos but a cant live with it. dont want to go to vw kirkcaldy causes they useless fu**S anyone had this prob? any ideas guys? am i looking at big bucks being spent???
Hi m8 - I starting having real probs with 1st gear and reverse a few months after having the pedal box done. I'm now the proud owner of a new clutch!
Couldn't convince dealers that there was a link between the work on the pedal box and subsequent gear change problems. There are a few ppl on here who have had similar though by the looks of things.
Good luck!
Good luck!
Having the linkages realigned should be a 10-minute job IIRC. They use a template to realign the linkages and it's a fairly straightforward job I think. Can't cost much at all, surely?
And the clutch is heavy just as standard yes. I never really realised this until I had a rental car for two weeks, and then when I got back in the Polo after this two-week gap, I put my foot on the clutch and just went like this:
Alright all..,,,my gear/pedal box experience is as follows -
If you're having probs getting it into gears - BUT it doesn't get worse the longer you drive it, then it'll be the linkages problem (and least costly - sure someone has posted a cost on here somewhere before....£20??).
BUT, if the gear changing gets worse the longer you drive it, i'd say your pedal box has cracked again! - which will happen if your clutch is too heavy! I had a heavy clutch (i mean REALLY heavy!) which in turn broke the pedal box again (after the recall!). I had the box replaced again (under warranty again), and had a new clutch fitted (which i paid for - £240 for a sachs clutch). Its much better now but it's still a heavy clutch - just not as ridiculously heavy as before.
ModifiedMadness
- Sponsor
