IS THIS A GOOD DEAL
IS THIS A GOOD DEAL
is this a good deal,
2000 VOLKSWAGEN POLO 1.6 GTi 3dr Hatchback,
Petrol, 65,000 miles, . 3Doors, Manual, Silver, PAS, ABS, E/Windows, E/Mirrors, H/Seats, Clim/Control, Leather sport interior, C/Coded, Front fog lights, Drivers & Passenger airbag, R/Cass+6CD, CAT1 Alram & immobiliser, FSH, TAX&MOT. £5,295. ono.
im gonna try get him down to about 4700 4800 u think this is likely, any known problems i should look out for
Check out Parkers guide and it will tell you how much the car is worth.
I got the same as what you are looking at, but without the leathers and had done 35,000 miles for £6,500.
Find out if the clutch pedel box has been changed cause all polo gti have a problem with this and i mean ALL. it should be covered under warrenty anyway.
oh what colour is it by the way??
SilverDNK69 wrote:Check out Parkers guide and it will tell you how much the car is worth.
I reckon if you can get the seller down to around £4700-4800 as intended, you'll have a good deal IMO
Good luck!
Its naturally heavy, you get used to it the more you drive the car, but it would be worth double-checking that the pedal box recall work was carried out - pop into a local VW dealership and ask them to check the service history of your car and this will confirm whether or not the recall was done. Letters went out to all GTi owners at the time of recall but some will have inevitably been lost in the postal system/sent to a previous owners address (the latter if a sale was made at around the time of the recall).
Once you get used to it the clutch will become second nature, I don't really register the difference until I use a different car!
PhilGTi
- Platinum Member
Not true. My clutch is very light...?Si_GTi wrote:Its naturally heavy, you get used to it the more you drive the car, but it would be worth double-checking that the pedal box recall work was carried out - pop into a local VW dealership and ask them to check the service history of your car and this will confirm whether or not the recall was done. Letters went out to all GTi owners at the time of recall but some will have inevitably been lost in the postal system/sent to a previous owners address (the latter if a sale was made at around the time of the recall).
