Problem with 51 reg Polo PLEASE HELP!!
ModifiedMadness
Sponsor
Post by ModifiedMadness »
I hear it when I open my door as well :D
stubs
Post by stubs »
Have any of you that also experiencing this noise have aftermarket alarms fitted to your cars, or are they standard?
She claims that she asked a VW tech about the noise, and they said it shouldn't do it, and its probably because of the alarm. They also told her that the fuel pump primes when the ignition is turned on. They think that its something to do with the fuel circuit being immobilsed by the Clifford, even though it isn't.. only the started & ignition circuit are immobilised by it.
inder
Post by inder »
I still don't think it has anything to do with the alarm, for the reasons you said
If the sound is 'bad' then get it checked out, but if its like a whine for a short time, its 'okay'
laura_fairy_22
Post by laura_fairy_22 »
yeah, this is normal.... its like the sound when you turn th key before you switch on the engine.....? think its something to do with activating the electronics in the car?!
dont think its to do with the alarm, as i dnt have one :s
polopowah
Location: Hertfordshire Drives: Ford Puma 1.7 Enjoys: Mowing grass
Post by polopowah »
laura_fairy_22 wrote:dont think its to do with the alarm, as i dnt have one :s
that'll be the 1.0 then :D
-Ben-
laura_fairy_22
i've got a 1.4 16v!!!
polopowah
Post by polopowah »
double :o:o
no fogs? :cry:
-Ben-
laura_fairy_22
double what!??! sorry im blonde! :oops: :cry:
Si_GTi
Moderator
Post by Si_GTi »
double surprise! :lol:
polopowah
Post by polopowah »
yup indeed 8)
-Ben-
jon_poloV
Sponsor
Noise!
Post by jon_poloV »
think youl find its the fuel pump!
jon
inder
Post by inder »
nowt to do with your alarm
basically, stop worrying :)
MisterMinty
Post by MisterMinty »
Yes, can confirm its the fuel pump. When the car is "activated" the pump runs for about 2-3 seconds to bring the pressure in the line up to the correct level (about 2.5 bar for you techies ;) ) so when you turn the engine over, fuel is immediately avaiable to the injectors, and hence the engine starts immediately...i hope! BTW, if you've left the driver's door open for a while, say, while cleaning the insides out, the fuel pump will do this procedure again. It's to keep the car in readyness to start. Also, the motor on the throttle will make a click to ensure its able to move freely as well.
:roll: Only know all this guff cos I've just changed my fuel pump to something more meaty...fortunately didn't get too much petrol everywhere...thrid degree burns don't strike me as much fun. Is it time to get an extinguisher for my car? :oops:
